28
The A-10 Warthog is built around a 30 mm cannon that fires depleted uranium rounds, 65 of them per second.
I heard from someone who worked on the flight controls a long time ago, that when the cannon is fired it provides more thrust than the engines. Is this true? What are the effects of this?
Update
The original question was answered by @Gypaets: thrust of the cannon is comparable to thrust of one engine. The wikipedia article on the GAU-8 cannon mentions that effects of thrust of the cannon are well accounted for by placing the firing barrel at the centre line of the air frame. Ron Gordon's answer reveals some interesting side effects from spooling the cannon up and down when operating - the aircraft bucks. It's a big cannon.
Image source
    $\begingroup$ I've heard it produces more thrust than a single engine, not both. $\endgroup$
    – DeltaLima
    Jul 1, 2017 at 11:08
  • 12
    $\begingroup$ mandatory link: what-if.xkcd.com/21 (scroll towards the middle for the section on the GAU-8/A) $\endgroup$
    – Federico
    Jul 1, 2017 at 11:32
  • 15
    $\begingroup$ It's possible the thing you're forgetting is the cannons only produce force momentarily, the engines produce force continuously. $\endgroup$
    – Fattie
    Jul 1, 2017 at 15:43
    $\begingroup$ If the canon produces thrust equivalent to one engine, for 200 ms, then this is equivalent to power down an engine during 200 ms. No big deal I suppose, the vertical stabilizers should be able to cop with that, specially if the canon is not remote for the longitudinal axis. $\endgroup$
    – mins
    Jul 1, 2017 at 19:03
    $\begingroup$ @Fattie Where did you get the impression I'm forgetting that? $\endgroup$
    – Koyovis
    Jul 1, 2017 at 23:03
29
The A-10 uses a GAU-8/A. According to Wikipedia:
The average recoil force of the GAU-8/A is 10,000 pounds-force (45 kN), which is slightly more than the output of one of the A-10's two TF34 engines (9,065 lbf / 40.3 kN each). While this recoil force is significant, in practice a cannon fire burst only slows the aircraft a few miles per hour in level flight
Your statement is only partially true: two engines have more, but one engine has about 10% less thrust than the recoil force of the cannon.
The recoil force of MiG-27's GSh-6-30 was even larger: 60 kN.
As pointed out in a comment by @tj1000 the recoil of the GAU-8/A wasn't such a problem as the smoke from its shell propellant. If you're looking for the video mentioned in the comment (test pilot ejection due to engines out after firing ammunition with a new flash suppressor) this is the link (12:08-13:59).
  • $\begingroup$ Can it still fire the gun when flying on one engine? $\endgroup$
    – Koyovis
    Jul 1, 2017 at 12:11
    $\begingroup$ @Koyovis I suppose it is more or less like airebrakes: it reduces the total energy, so yes you can still fly but not maintain a leveled flight at constant speed. $\endgroup$
    – Manu H
    Jul 1, 2017 at 12:33
  • $\begingroup$ And perhaps struggle with the yawing moment. $\endgroup$
    – Koyovis
    Jul 1, 2017 at 13:18
  • 8
    $\begingroup$ The big problem with the GAU-8 and the A10 during development wasn't recoil, it was the smoke from the cannon shell propellant blowing the engines out. If you've ever seen the oft repeated video of a pilot punching out of an A10, and the aircraft then crashing into a desert, that's what happened: during a test, the cannon smoke blew out both engines, and the pilot couldn't get them restarted. $\endgroup$
    – tj1000
    Jul 1, 2017 at 15:45
    $\begingroup$ I first saw that film around 1980, in Air Force ROTC training. This was during extended testing of the A10. When the pilot got below 2000 feet and the engines still hadn't restarted, they told him to get out. They showed that film as it was shot on a high speed camera (to record the cannon firing), and it was a good example of an ejection. They pointed out that as the pilot didn't have his head completely vertical, he did get a cracked vertebrae from the ejection, but no permanent damage. $\endgroup$
    – tj1000
    Jul 1, 2017 at 22:38
24
Not only does it affect air speed, but also angle of attack (AoA) and yaw. The gun is well forward of the center of gravity (CG); so add to the recoil vectoring a build up gyroscopic torque as the gun spins up and down. As air speed decreases, maneuvering approaches instability, thus placing a limit on the length of a safe burst determined by available energy (altitude, AoA and air speed.) However, grouping accuracy and ammo conservation usually are more limiting than the effect of gun "drag". Each A10's gun performance is distinctive. Once a burst begins, the aircraft will pitch and yaw in its peculiar manner. On the HUD you might find a wad of gum placed there by the pilot after his first aiming burst to show the direction of push.
The A10 employment scenario has always included battle field loiter to provide air cover, ensure extended engagement coordination, and provide tactical intel directly to the ground commander! Even low and slow, its hard to hit. Most infantry borne G-to-A missiles are IR guided. The A10's exhaust is hidden from below by the horizontal stabilizer; and the RAW/IRW system can automatically launch "angel flares" when the launch is detected, thereby negating any IR guidance system. Meanwhile you have just poked the bear and left your location for immediate response with an array of launch-and-leave air-to-ground guided weapons.
  • $\begingroup$ Are pilots matched with airframes, so that they gain experience with one particular set of peculiarities? Can the A-10 continue to fly the mission on 1 engine? $\endgroup$
    – Koyovis
    Jul 2, 2017 at 2:02
  • $\begingroup$ Yes. Absolutely. The pilot is a member of the assigned combat team for that aircraft, training, exercising, and deploying together. $\endgroup$
    – Ron Gordon
    Jul 2, 2017 at 8:32
    $\begingroup$ Comments right on. Your picture shows how the engines are protected from ground fire by control surfaces that will have to be shot away first. From the technical descriptions of thrust limitations you have elsewhere, an engine failure is usually a good reason for abort. But the exigencies of war dictate risk taking proportional to the objective. The A10 can loiter on one engine, providing surveillance and coordination until help comes. It also carries an array of guided weapons that can be used, if the bomb/nav release systems are still functioning. $\endgroup$
    – Ron Gordon
    Jul 2, 2017 at 16:31
    $\begingroup$ @Koyovis - I would assume definitely RTB. The A-10 isn't exactly sporty to begin with. Without a second engine, you lose altitude or jettison stores. AFAIK, that "one engine... half of a wing missing" etc is clean w/o stores or other damage. It's physically possible to do some missions one one engine, but I doubt it's advisable. That's my impression from pilot comments. The survivability features are designed to keep the pilot alive and bring the plane home, not let it keep fighting while shot up. Overall, it's the least survivable USAF fighter, not the most. $\endgroup$ Jul 4, 2017 at 10:42
    $\begingroup$ @HephaestusAetnaean The survivability features are designed to keep the pilot alive and bring the plane home, - sounds like some pretty sensible survivabilitynfeatures to me. $\endgroup$
    – Koyovis
    Jul 4, 2017 at 15:46
As Gyrates points out, no. The recoil from the GAU-8 doesn't completely counteract the thrust of both of the A10's TF-34 engines, but it will definitely slow the plane down. That is a factor before firing the cannon - is your airspeed sufficient to withstand a slowdown?
The same holds true of WW2 fighter aircraft with multiple heavy weapons - firing at slower speeds could stall the plane.
One airplane that did battle serious recoil issues was the WW2 B25 variant that mounted a 75mm cannon in the nose. Apparently, the recoil from the cannon was quite severe, and definitely impacted airspeed.
AC130 crew report that firing the side mounted 105mm howitzer will boot the tail of the plane around quite a bit.
    $\begingroup$ Well said. I would think - as a non pilot, jsut from some logic - that part of the problem is that on an attack run the A10 would come in low and SLOW - to give more time for the run. Which means there is not a lot of reserve before hitting stall speed. And the engines possibly are not working at full power either. Which means the question is really "does the gun slow down the plane significantly". Engine power does not really matter in a scenario I describe. $\endgroup$
    – TomTom
    Jul 2, 2017 at 6:03
  • $\begingroup$ Fortunately, most A10 attacks with the gun are made with the plane in a slight dive - partially to keep the target centered, and partially to keep a reserve of speed - acceleration is quicker when a plane is already diving. I don't think the GAU8 has to stay on target for very long to destroy whatever it is aimed at. $\endgroup$
    – tj1000
    Jul 2, 2017 at 19:08
  • $\begingroup$ Yeah, but I think someone envisioned a battlefield with a tank battle going on and an A10 slowly going over the battlefield obliterating a dozen or so tanks. Not that this is the case these days ;) $\endgroup$
    – TomTom
    Jul 2, 2017 at 19:10
    $\begingroup$ Oh, yes! two A10s, 23 tank kills, one day. .theaviationist.com/2012/12/20/warthog-in-action And its not just the plane!! These guys used a dirt strip to refuel and reload. We practiced ground turn around on the A10 bring it down to less than 15 minutes without peacetime safety restricts prohibiting loading bombs and fuel simultaneously. In this scenario, the pilot is the guy pump his on JP fuel. $\endgroup$
    – Ron Gordon
    Jul 5, 2017 at 1:09
  • $\begingroup$ A figure I saw was that the 8 M2's on a P47 would put the equivalent of around 400hp in reverse. Not enough to stop the plane, but definitely a factor. If the aircraft was close to stalling in a drastic maneuver, firing the guns could push it into a stall. $\endgroup$
    – tj1000
    Aug 29, 2019 at 17:10
