What are these two teardrop shaped thingamabobs on the bottom of the Panavia tornado? Circled in blue
They could be hardpoints but I haven't found any photos where anything would have been mounted there. They don't look like hatches. And they don't seem to be any kind of vortex generators either. What purpose do they serve?
Click to view full-sized image: Circled in red
Here's a few closer images:
Banking
Underside
    $\begingroup$ Maybe chaff launchers? $\endgroup$
    – Ron Beyer
    Commented Jun 27, 2017 at 21:05
    $\begingroup$ They're not symmetrically aligned, so probably not hardpoints? (That's a guess -- it just seems like if you're going to be mounting things on the plane, even close to the centerline, you'd probably want them symmetric.) $\endgroup$
    – yshavit
    Commented Jun 28, 2017 at 3:45
    $\begingroup$ So, I did find something online that says they're "engine oil" -- I'm not sure exactly what that means, though maybe it's as simple as "here's where you plug in to change the oil"? The page I found it from looks like an official document, though, and says "NATO RESTRICTED" on every page. It's easily found on google, but I don't know if I should be posting it here. Anyone have guidance on that? $\endgroup$
    – yshavit
    Commented Jun 28, 2017 at 4:19
    $\begingroup$ @yshavit Big Red has google too ;-P I'm sure it's fine to post. $\endgroup$
    – SnakeDoc
    Commented Jun 28, 2017 at 14:47
10
They appear to be related to changing the oil.
The Tornado's flight manual is available online. Page 448 shows what seem to be the features you're talking about:
Tornado engine oil
The features are the ones marked as "12." The previous page has a legend describing them simply as "engine oil."
This probably also explains why they're not placed symmetrically. It seems the engine oil access is off to the side, so each teardrop is a bit to the right of the engine's center line (that's most visible in the second picture).
  • $\begingroup$ Didn't even occur to me that the flight manual would be available, much other interesting information there as well. Thanks for sharing! $\endgroup$
    – Steve
    Commented Jun 28, 2017 at 18:35
    $\begingroup$ @Steve If NATO comes after me I hope the 45 InternetPoints will be worth it... ;) $\endgroup$
    – yshavit
    Commented Jun 28, 2017 at 19:08
From my remembered knowledge as a Tonka Av Tech they are the fairings for the RB199s Oil breathers to allow the oil system to vent oil if the sump is over full or over pressured. A Tonka sootie mate may well tell me Im wrong.
