11
I was on a LATAM flight a couple days ago, and decided to have a read through their VAMOS magazine. As a lot of airlines do, they had a couple of pages on their fleet, and also a double spread on one specific plane.
This plane was the 777, which was a little bit surprising as they are about to get rid of those I think. Anyway, it had all the usual facts and figures, and also a couple of highlights about the plane.
I managed to find a web copy of the magazine, and the picture is below:
https://issuu.com/spafax/docs/vamos_latam_junio_2017_web
One of these highlights is the wheels, and it says (roughly translated):
Each of the wheels is capable of supporting a maximum of 29,294 kg.
My first reaction was "That's pretty impressive!", then "I wonder how much above the MTOW that is?" The MTOW is specified at the side there: 351,530 kg, which correspondes to the 777-300ER.
So 29,294 x 6 x 2 = 351,528
Oh. That's under the MTOW. I wonder if there's some rounding off here:
So 351,530 / 2 / 6 = 29,294.166 - yes there is.
I was surprised that the maximum each tyre/wheel could take summed up to the MTOW, as I thought that they would experience larger forces on landing. Also, what would happen if a tyre blew?
So, does the maximum load for a tyre/wheel have anything to do with the MTOW? Or is this just marketing guys jumping the gun?
I have seen this question How is Maximum Take Off Weight determined? and that says that the manufacturers determine it, and it is based on the required payload of the aircraft and the design configuration, which doesn't really answer this question.
Edit with extra info mentioned in comments:
When stationary, the wheels will have a total force on them of 351,530 kgs, which according to this magazine is their max. When landing, the wheel like have to bear a weight of 251,290 kgs, plus the force of the landing. In my mind, the extra force of the landing would push the total above the MTOW, but this is just in my mind so I'm probably wrong :P
    $\begingroup$ Maximum take off weight is often higher than maximum landing weight specifically for that reason. There are quite a few aircraft that can take off but have to burn fuel before it can land again. $\endgroup$
    – Ron Beyer
    Jun 27, 2017 at 12:46
    $\begingroup$ "surely"? have you run the formula? or is "surely I am right in thinking this and I can't be wrong?" :P If you run the formula you'll see that one element is the weight, the other the speed of impact. You could land with 1% of the MTOW and still completely destroy your aircraft if the speed is excessive. $\endgroup$
    – Federico
    Jun 27, 2017 at 12:56
    $\begingroup$ @Federico I'm asking you guys for the formula :P $\endgroup$
    – CalvT
    $\begingroup$ Seat back brochures aren't an accurate representation of the engineering behind this. The wheels are not at the maximum loading at MTOW. The weight is more determined by stopping the aircraft prior to V1 during take off given the configuration of the aircraft. It isn't really about how much the tires hold. There is no one "formula" to cover this. $\endgroup$
    – Ron Beyer
    Jun 27, 2017 at 13:02
    $\begingroup$ @CalvT븃 Not so much "jumped the gun", but trying to impress passengers with numbers that they probably don't fully understand. The gear system itself (tires included) can withstand landing pressures significantly higher than that. $\endgroup$
    – Ron Beyer
    Jun 27, 2017 at 14:06
Boeing1[pdf] specs for 777-300ER:
  • Max taxi weight: 777,000 lbs (352,442 kg)
  • Max take off weight: 775,000 lbs (351,535 kg)
  • Max landing weight: 554,000 lbs (251,290 kg)
Bridgestone2 specs for approved tires:
  • Main: 66,500 lbs (30,264 kg) x 12 = 798,000 lbs (361,967 kg)
  • Nose: 44,500 lbs (20,185 kg) x 2 = 89,000 lbs (40,370 kg)
  • Total tire rated load = 887,000 lbs (402,337 kg)
So at taxi weight on all 3 gear there's roughly a 110,000 lbs / 50,000 kg margin (about 14%).
At max landing weight, main gear only, there's a 244,000 lbs / 110,677 kg margin (44%).
At MTOW there's about a 112,000 lbs / 51,000 kg margin (14%) on all gear, but only a 23,000 lbs / 10,400 kg (3%) margin after nose gear lift off.
But, when the nose gear lifts off the ground the wings are supporting nearly all of the weight. Their numbers are pretty close to what the manufacturers list. I think you're just not accounting for the nose gear at takeoff and the weight difference at landing.
As far as Is the MTOW determined by the wheel maximum supported weight? It's the other way around. The MTOW determines how many tires of what weight rating are needed.
A more important tire consideration is speed. The tires are rated at 204 kt. This paper gives an example of a 747 at 825,000 lb there is a weight margin of 30,000 lb. But liftoff speed is 199 kt, so there's only a 5 kt speed margin.
Another factor in MTOW is the ability to maintain control after takeoff. Just getting airborne isn't enough. Northwest 255 managed to lift off with flaps improperly set, but couldn't maintain control and crashed. Air Florida 90 also lifted off, but crashed almost immediately due to icing and less than full power from the engines.
An aircraft too heavy for the design can suffer the same fate. Ernest Gann described an incident where a C87 (B24 derivative) with an accidental overload of fuel he was flying out of India during WW2 almost hit the Taj Mahal, because it would barely stay airborne with no ability to climb or change direction without stalling. Only a last minute application of flaps got it over the towers.
An aircraft will have a certified MTOW which it can't exceed, but keep in mind the actual MTOW for a specific flight can be lower (and often is). MTOW will always be the lowest of the following limits:
Field Length (runway length, condition)
Climb
Obstacle Clearance
Tire speed & brake energy
Landing Limit weight (i.e. can't plan to arrive at something greater than MLWD)
