Has there been evidence of ejected material striking the fuselage or other parts of an aircraft forward of the engine itself?
Which of the various forces acting on rotor blades dominates the trajectory of pieces in the case of a blade failure?
Other than rotor break-up, what kinds of engine malfunction typically cause component separation, and in what direction(s) is material ejected?
    $\begingroup$ There are many studies on the topic of uncontained engine failure. e.g.: Large Engine Uncontained Debris Analysis, or Uncontained Engine Debris Analysis Using the Uncontained Engine Debris Damage Assessment Model, and Uncontained Engine Failure. $\endgroup$
    – mins
    Jun 25, 2017 at 23:51
  • $\begingroup$ There is one crash I can think of, where the engine itself separated, traveled forward and struck the leading edge of the wing. This was American Air Flight 191. $\endgroup$
    – Ron Beyer
    Jun 26, 2017 at 0:18
  • $\begingroup$ QF32 had an uncontained engine failure in which debris went in multiple directions, but by pure luck avoided the fuselage. $\endgroup$
    – Thomas
    Jun 26, 2017 at 3:54
  • $\begingroup$ Technically speaking, AA191 was not an engine failure. It was a pylon fuse pin failure due to faulty maintenance techniques, leading to partial and then total separation of the pylon with engine attached. The engine was working just fine when it pivoted upward and then over the wing due to pylon separation, tearing out the leading edge flap. $\endgroup$
    – tj1000
    Jun 26, 2017 at 17:23
For debris ejection out of the engine, the failure of the engine and the failures that follow that create debris; the design criteria is that the failures must be contained in the cowling and the debris exits through the exhaust. Here is the link to the FAA Advisory Circular for designing for catastrophic failure: AC 20-128A
Here is another link that is more devoted to prior uncontained engine failure.
    $\begingroup$ Debris should be contained (and there is a check for this to certify the engine). However they are not always, so the accidents, I think the question is about the latter cases, not what is expected (to some extent). $\endgroup$
    – mins
    Jun 26, 2017 at 12:19
When the fan disk failed during UA232, there was damage forward of the fan disk itself. See also the associated damage image. While this was not forward of the engine nacelle, it seems to address the intent of the question.
