On all Airliners, there is a speed callout by the PNF at some point during take-off, usually at 80 or 100 KIAS.
Whats the reason for those callouts? And why are some at 80 KIAS and some at 100 KIAS?
  • $\begingroup$ @Federico -- this is before V1 $\endgroup$ Jun 21, 2017 at 11:46
  • $\begingroup$ @UnrecognizedFallingObject right, sorry. but not too far from it (depending on weight) deleting old comment anyway. $\endgroup$
    – Federico
    Jun 21, 2017 at 11:56
This call serves two main purposes. The first is to verify that both airspeed indicators are showing the same speed. Since airspeed = life, it's best to find out that one of them is faulty on the ground rather than in the air.
The second purpose is to distinguish a high-speed rejected takeoff from a low-speed one. Below 80kts (or 100kts or another speed set by the manufacturer and/or airline), a takeoff would be rejected for almost anything out of the ordinary.
But rejecting a takeoff at high speed carries a lot of risk - like brake fires, tyres exploding, directional control difficulty, etc. So above 80 or so knots, a takeoff will only be rejected in the case of major failures. Some modern aircraft even inhibit minor warnings from appearing after 80kts until the aircraft is airborne, because rejecting the takeoff is not worth the risk, so don't saturate the pilots with unnecessary information.
This page goes into some detail about what you would reject a takeoff for at low speed vs high speed. The criteria may vary slightly amongst airlines but the general themes are the same.
    $\begingroup$ There is a third reason. Many airline SOP's use the 80 or 100 call as a crosscheck against pilot incapacitation. If the Pilot Flying does not respond, the Non-Flying Pilot will assume control and reject the take-off. $\endgroup$ Jun 21, 2017 at 20:19
