I'm having difficulty seeing the difference between a stationary plane and a moving one.
  1. When you start the engine in the C172, the blades on the prop are spinning - but the plane doesn't move at all.
  2. When taxiing out, it feels like the forward motion is being provided by the wheels - like in a car.
  3. When taking off, you can audibly hear the change with the throttle increases.
  4. In cruise, the plane almost looks the same from the inside as when it's on the ground (i.e. prop spinning). Which is where the weird psychological block is for me - the plane feels stationary even though the horizon/backdrop is moving towards you, and i get that fear kick in that it could drop because there's not enough momentum.
I'm trying to understand what the propeller is doing in each of these stages: rest, taxi, take-off, and cruise - as well as how the plane is pushed forward with thrust, if it can just sit there and not move with the prop spinning away.
My question(s): what's happening with the engine, throttle, and propeller that provides the thrust, and/or forward momentum? Does the plane stay stationary when you turn the engine on because there isn't enough RPM to draw it forward, or will it automatically pull forward and the brakes are just being held on? Does the plane accelerate in proportion to the prop RPM? What's different with the prop when stationary, compared to when it's taxiing or taking off?
  • $\begingroup$ Hi, and welcome to Aviation.SE. It's good that you came here and asked these questions but, it is not the best thing you could have done. Questions like these should first of all be discussed with your instructor. It is vital in order to become a competent, safe pilot, that you build a two way relationship of trust with your instructor. If they cannot, or will not not answer questions like these, then you should find another instructor. Over the next 60 odd hours of flying together, you will both put your life in the others hands. That demands trust. $\endgroup$
    – Simon
    Jun 17, 2017 at 5:46
    $\begingroup$ "the plane feels stationary even though the horizon/backdrop is moving towards you, and i get that fear kick in that it could drop because there's not enough momentum." This is why you scan the airspeed indicator and practice stall recognition. I see that this is a year and a half old, hope your training is going well! :) $\endgroup$ Jan 30, 2019 at 0:27
11
When you start the engine in the c172, the blades on the prop are spinning - but the plane doesn't move at all.
When the propellor is idling its obviously moving air, this you can see, feel, and hear, however its simply not spinning fast enough to provide enough thrust to overcome the force of the plane sitting on the ground. Basically this is comprised of friction air resistance as well as some limited brake pressure that is usually applied. With fresh bearings, on level ground an idling prop may very well pull a plane forward. For the record it is a matter of certification that the brakes on an aircraft can hold it in place at full throttle. It also takes a bit more force to get a plane rolling than it does to keep it rolling. You need to break static friction to get rolling but then only provide enough power to overcome kinetic friction.
Generally speaking static friction is higher than kinetic friction,
enter image description here (source)
The first time you are in small plane you associate it with a car. You equate that feeling with a car and thus you think intuitively that the tires are pushing you. In a car you could not be able to tell the difference between a front wheel drive and real wheel drive setup the idea is the same here.
I don't think there is a question here.
The plane feels stationary because you are in unaccelerated straight and level flight. In other words the forces are balanced about the aircraft. You feel nothing because there is nothing to feel ("feeling" is really another word for acceleration). This is different than a car, our road system lends its self to speeding up/slowing down often and unless you are on a very straight highway at night when its empty its less likely you are in unaccelerated movement in a car. The twits and turns of the road and the constant passing and slowing down of cars leads to a "feeling" of movement.
  • $\begingroup$ I know I hold the brakes when starting a C172, I was surprised when I hunted down a POH that didn't mention brakes during start :). $\endgroup$
    – bartonjs
    Jun 17, 2017 at 0:46
    $\begingroup$ @bartonjs Im not sure what 172 you were flying but in this POH the BEFORE ENGINE START section clearly states, "4. Brakes -- TEST and SET. " $\endgroup$
    – Dave
    Jun 17, 2017 at 0:50
  • $\begingroup$ d'oh. I jumped right to ENGINE START (With Battery), then saw you'd answered and stopped looking. $\endgroup$
    – bartonjs
    Jun 17, 2017 at 0:52
    $\begingroup$ In the air you have no close-by reference to judge your speed. Far-away objects seem to stand still, relative to the plane. Just wait until you are near a bird … $\endgroup$ Jun 17, 2017 at 7:26
    $\begingroup$ @simon Oddly enough, I used to own a Cutlass Sierra. I adopted it in the summer and the first time I drove it in snow I was amazed to find out it was front-wheel drive. I guess it sort of depends on how you drive. If you don't accelerate very strongly it's harder to tell. $\endgroup$
    – TomMcW
    Jun 17, 2017 at 18:28
Answers to points:
1) If you don't have the brakes set, chocks on the wheels, or a rough surface, the plane will move. Just ask anyone (me, for instance) who's had to hand-prop a plane by themself :-)
2) It may feel like that to you, but your perception is wrong.
3) Yes, the engine & prop noise changes, because you are applying more power, which makes the engine and prop turn faster. Ever played with a bullroarer as a kid?
4) I'm not sure what you're asking here. If it's about the appearnce of the prop, that's down to the human flicker fusion rate. Basically you can't perceive anything that happens more than about 25 times a second - it all just fuses together. So just as you can watch movies without seeing that there are individual frames, you can't see the prop blades turning, just a blur.
If you're asking why the plane seems almost stationary at altitude, that's because your reference points are far away. Just as in a car, the distant hills seem almost stationary while the dotted white lines of lane markers blur together. Or as a practical experiment, find a little-used runway and fly down it a few feet off the ground. (Also good to learn heading corrections in crosswinds &c.)
There is no absolute concept motion. Motion is always relative. Whether something is steady or moving depends purely on your choice of reference. And since this is still the same situation, it follows you can't actually feel motion.
Note that at this very moment, you are rotating with Earth at up to 465 m/s (depending on your latitude; where I am it is still about 300 m/s), orbiting the Sun at 29.8 km/s and orbiting the centre of the galaxy at whoping 220 km/s. Can you feel any of that motions? And how much difference does 240 m/s (reasonable speed for a cruising jet) make compared to that?
The propeller is spinning, and providing some force, but this force is balanced by the wheel friction, and usually the brake friction. Since all forces are in balance, the aircraft is not accelerating and remains steady.
  1. When taxiing out, it feels like the forward motion is being provided by the wheels - like in a car.
Motion is not a thing that could be provided. Force can.
The force to get the plane moving, and to balance the friction so it does not stop, is provided by the propeller. However, the wheels do provide one thing: vibrations.
The ground is never perfectly smooth, so anything rolling on it, be it a car, train or taxiing aircraft, bounces around a bit. Now bouncing is acceleration, and unlike motion, there is an absolute notion of acceleration and it can be felt. And from your experience with cars, you learned to associate the vibration of rolling with motion.
  1. When taking off, you can audibly hear the change with the throttle increases.
The propeller spins faster and accelerates the air to faster speed, so the sound increases.
The increase in power is so that the plane accelerates to the point where it is fast enough relative to air to be able to take off.
  1. In cruise, the plane almost looks the same from the inside as when it's on the ground (i.e. prop spinning). Which is where the weird psychological block is for me - the plane feels stationary even though the horizon/backdrop is moving towards you, and i get that fear kick in that it could drop because there's not enough momentum.
Air does not have the same kind of small bumps ground does. When it's calm, it is much smoother. And while turbulent air may bounce you around a lot, the characteristic is quite different, so you don't get that feeling you associate with motion.
That, combined with the lack of nearby visual references to judge your speed from, means that you don't feel like moving.
You similarly wouldn't feel like moving sitting on the upper deck of large ocean-going ship even though it might be going 50 km/h—the sea surface is too far below for visual reference and the vibration is not there. And similarly you don't feel like moving just sitting at home even though you are still hurling through the space at 190–250 km/s.
    $\begingroup$ As a counterpoint to that large ocean liner, consider the sensation of speed when sailboarding in a brisk wind, with your head a few inches above the water :-) $\endgroup$
    – jamesqf
    Jun 17, 2017 at 17:55
