This image (so commonly used here that the first image reference for it that pops up in a Google search for "jet engine diagram" points back to ASE!)
Jet engine
From Wikipedia
Shows the housing of the actual "jet" section very tightly packaged around the various sized compressor and turbine stages, leaving a diverging/converging path for the bypass airflow.
It seems to me that it would make more sense for the packaging of the inner jet engine to be a fairly even cylinder so the bypass air flows smoothly around it and out the back of the nacelle as I've attempted to depict with the blue line at the bottom, or a somewhat converging shape as I've depicted with the red line at the top.
Source: personal modification of above mentioned Wiki picture. Don't laugh... I drew that with my thumb-operated trackball.
However, as I've typed this question up and looked at the diagram more, I can see where the converging path around the low-pressure turbine section of the jet would add additional pressure to the bypass air and, therefore, additional energy to the escaping air.
Is this simply an "artist's concept" of a cross-section of a turbofan engine, or is it an accurate depiction of the internals?
Note: I do understand that within the jet section of the engine the shaping needs to be tightly packaged to ensure the jet-internal air flows exactly where it's needed, my question is about the flow of the bypass air only.
  • $\begingroup$ When I look at pictures online, it seems like not only do they not have the ducts you suggested in the bottom picture -- but the ducts from the top picture are littered with tubes (example). That seems like it's cause all sorts of turbulence. Do the nacelles that the engines sit in also contain the inner ducts for the bypass? $\endgroup$
    – yshavit
    Jun 14, 2017 at 16:46
Strictly speaking, no. It is an artist's concept to help us understand the engine schematics better. A better figure would look some thing like this :
Engine cutaway
GE-90 Cutaway; image from web.stanford.edu
The blue colored region more or less shows the 'cold flow' region (where the bypass air flows). This graphic is better for two reasons- not only does it show that much of the flow takes place in the cold flow half-ducts, but it also shows that how the pipes and tubes that are all over the place are covered.
The figure you linked in the question doesn't show the cold air flow ducts, for simplification. Also, the shape and size of the bypass duct varies from design to design (though they are similar overall).
Two and three shaft
Differences between two and three shaft engines; image from 1.bp.blogspot.com
In the above figure, you can see that the though both the similarly shaped bypass ducts converge, their location and length is different. Of course, in the real aircraft, these ducts host the thrust reversers, as explained by @mins elsewhere.
  • $\begingroup$ Any idea why the leading edge on the top of the duct extends farther out than the bottom? $\endgroup$
    – yshavit
    Jun 14, 2017 at 19:13
  • $\begingroup$ @yshavit - that's a great basis for a whole new question! $\endgroup$
    – FreeMan
    Jun 14, 2017 at 19:19
  • $\begingroup$ Looking at this again (4 years later), I notice that the drawing that I posted in my question basically matches the hot section of the drawing in the answer, my red line sorta matches the inner shrouding that separates the cold flow from the jet and all it's unaerodynamic plumbing, and my blue line basically matches the nacelle. Not bad for a rookie! :) $\endgroup$
    – FreeMan
    Sep 24, 2021 at 11:15
