On the Airbus A320 there is a pack flow knob and you can either select HI(120%), NORM (100%), or LO (80%). You choose which one according to the number of passengers and ambient conditions. Obviously If you have a full flight and it is hot outside you would choose HI. Or if you have very little passengers and it is cold or even raining outside you would select LO. But is there a specific number of passengers when you would select HI or LO, or is there a specific temperature, or both?
From the A320 flight crew operating manual (FCOM):
The selector is kept to NORM in most conditions.
It can be turned to LO:
  • When the number of passengers is low. 115 passengers is indicative and there are local regulations about the quantity of air which must be delivered per passenger. Operators may have different instructions in their SOP.
  • When fuel is low for some reason. Using more bleed air increases fuel consumption.
  • It is also tempting for an operator to reduce fuel and maintenance costs by also reducing air flow. See this thread on PPRuNE.
Air flow can be increased to HI:
Automatically:
  • When the other pack is turned off.
  • When APU provides bleed air.
Manually:
  • When air is too wet due to perspiration and breathing. Dampness increases with the number of passengers.
  • Air in the aircraft contains smoke.
  • To intentionally increase tapping of bleed air from the engines, which increases compressor stall margin. This would be desirable while flying in a volcanic ash cloud.
Packs also provide air for pressurization purpose (PACK stands for pressurization and air-conditioning kit). In case of leakage, air flow can be increased. In emergency situations, bleed air can be replaced by ram air (ram air is normally only used for cooling bleed air, but doesn't enter into the pressurized sections of the aircraft).
  • $\begingroup$ So there is no specific temperature for HI $\endgroup$
    – Itzyoboi
    Jun 11, 2017 at 20:43
