18
In the wake of the Qatar diplomatic crisis, I saw this image from Business Insider:
Airspace in the Persian Gulf (source: Business Insider)
How is airspace in the Persian Gulf determined? Why, for instance, does Bahrain have such a disproportionately large amount of airspace for its size? And why is Qatar's airspace predominately to the east of the country? Is this related to air traffic routes in and out of the territory (e.g., lots of Qatari flights fly over Das island, despite it being part of UAE territory)?
    $\begingroup$ Can you link to the article that you found that map? I'm not sure that it is saying the white-ish area is Qatar airspace, for example Bahrain has some small disconnected slice at the Southwestern corner of UAE, which is odd. $\endgroup$
    – Ron Beyer
    Jun 6, 2017 at 19:39
    $\begingroup$ Since the source is IVAO that's another reason to doubt the specific accuracy. $\endgroup$
    – fooot
    Jun 6, 2017 at 19:42
    $\begingroup$ ICAO shows that Qatar has no FIR: i.stack.imgur.com/r1dJp.png The white space in the BI picture seems to be the national airspace. The "Bahrain airspace" seems to be Bahrain's FIR minus Qatar national airspace. $\endgroup$
    – Federico
    Jun 6, 2017 at 20:28
    $\begingroup$ This might be the original article the image is from. This other article that shows a similar map. The latter seems to show "Bahrain (OBBB)" encompassing most of Qatar. The latter article says "Qatar has very little airspace; it is largely surrounded by Bahrain airspace (the Bahrain FIR)" which seems to confirm that the map actually shows FIR. $\endgroup$
    – user102008
    Jun 7, 2017 at 2:20
  • $\begingroup$ you do realise IVAO is a flight simulator organisation that merely simulates aviation? While they try to be reasonably accurate, there are differences with reality. $\endgroup$
    – jwenting
    Jun 8, 2017 at 5:52
14
The map you see is for Flight Information Regions (FIR's), that's different from sovereign airspaces.
Sovereign airspace by international law "corresponds with the maritime definition of territorial waters as being 12 nautical miles out from a nation's coastline. Airspace not within any country's territorial limit is considered international, analogous to the "high seas" in maritime law."
Can military planes fly across this "international airspace"? Yes. An example is Russian war planes flying very close to the UK airspace, passing through many FIR's.
An example for a disagreement is between Greece and Turkey, because they have so many islands between them. According to some sources just last month Turkey violated Greek airspace 141 times in one day. The point is, there are disputes over sovereign airspace just like with land borders.
Why, for instance, does Bahrain have such a disproportionately large amount of airspace [FIR] for its size?
It's a matter of "administrative convenience". Both Bahrain and Qatar gained their independence from the UK in 1971. It's quite likely the current FIR shapes were carried over from before and based on where the radars were initially installed.
[...] Qatari flights fly over Das island, despite it being part of UAE territory.
Checking the official Qatari aeronautical chart above, the Emirati islands are not part of Qatari airspace.
See below the official FIR chart for Bahrain, despite covering the area north of Qatar, airplanes in and out of Qatar still fly north.
To illustrate the operational and administrative convenience I've split the commonly traveled east-west airways between Saudi Arabia, Bahrain, Qatar, and UAE. Now you can imagine the impact it will have on ATC, flight planning, flying, etc.
To further illustrate the region, abeam the four countries the distance is a mere 150 NM, or 20 minutes in cruise. If the FIR is split, a single flight would need to contact 4 different frequencies in such a short time. And if that flight is descending/climbing to/from one of the four countries, multiplied by the amount of flights, then you can imagine the substantially higher workload on both ATC and pilots with regard to coordination and hand-offs.
A similar oversized FIR example is Singapore FIR (shown below).
(Source)
