In older jets such as 727 hush kits are used in the engines to reduce noise. In very modern jets such as 787 or 747-8F, chevrons are used for the same purpose. What happened in between? The switch to high bypass ratio turbofans alone is sufficient an improvement in engine noise that no special noise reduction device is required? (Not even hush kits?)
A hush kit:
A hush kit installed on a Swedish Air Force Sud Aviation Caravelle.
A chevron:
Rear view of a GEnx-1B on a Jetstar 787-8, showing noise-reducing chevrons
Generally speaking one is an add on and the other is integrated into the design. Over the years the FAA has implemented progressively more stringent noise regulations both for aircraft that are flying as well as to the full certification process. The changes came in stages and have been progressively altered for the past 30 or so years take a look at ยง36.103 Noise limits for the current regulation . You can find some of the FAA legislation here and the full text of the relevant FAR's here. As such newer engines will incorporate noise mitigation directly into the design as they need to pass the certification process. However in cases relating to older designs it may be cost effective to design an attachment (like a hush kit) that can be added to an existing engine to comply with regulations since the engine was certified at a time that the regulations were far more relaxed. Due to the letter of the law planes can be grounded for being non compliant so a hush kit may be cheaper than a new plane. For example this was the case with the Lear 23 which had required hush kits.
Interestingly at least one patent for a hush kit stresses that it is for an existing engine design.
BACKGROUND OF THE INVENTION
The present invention relates generally to jet aircraft turbine engines and, more specifically, to a hush kit for use on an existing engine and airframe.
You can similarly find the patent for the chevron here. Which describes it more as part of the engine than as an add on.
Yes indeed - the higher the bypass ratio, the lower the noise:
  • Noise is a function of the velocity of the accelerated air stream. For a given thrust, accelerate more air to a lower velocity and noise goes down (and efficiency goes up).
  • The bypass air is much slower than the turbine exhaust air, and surrounds it like a tube.
The hush kits were for previous generation noisy aircraft. I used to live and work near an airport, and could hear and see hush kitted aircraft take off. Caravelles, Iljoesjins, Tridents, made you look up and observe the pile of black smoke propelling the aircraft. Later, stricter noise regulations allowed only hush kitted screamers to take off, quieter but still smoking.
Article
    $\begingroup$ Noise is proportional to exhaust velocity to the power 6 according to NASA $\endgroup$ – ROIMaison May 22 '17 at 21:05
    $\begingroup$ Great research program, thx., It shows a very omplicated function of frequency, exhaust gas velocity, distance, and flight angle. Have amended the answer. $\endgroup$ – Koyovis May 22 '17 at 23:51
By clicking โ€œPost Your Answerโ€, you agree to our terms of service, privacy policy and cookie policy
