Are there any propeller or fan designs that hold the propeller or fan in the duct and do not have a boss or propeller shaft? This could reduce the drag of the centre. Are there any other advantages?
  • $\begingroup$ When I viewed this question earlier, there were a lot of comments and an answer from naysayers, for instance from a Cessna 172 pilot commenting on turbine engine design. Where did they all go? $\endgroup$
    – Koyovis
    May 21, 2017 at 16:58
  • $\begingroup$ Comments are ephemeral. You should not ever expect a comment to last. They can be deleted at any moment without notice. Usually, comments get removed (and moved to chat) when they contain a discussion. Comments are for asking clarifying questions or making small suggestions. $\endgroup$ May 21, 2017 at 23:53
    $\begingroup$ Yes comments are ephemeral. Just wish there would be more positive ones though. $\endgroup$
    – Koyovis
    May 22, 2017 at 12:07
Perhaps an aeronautic version of one of the Voith maritime systems? This one appears to be electrically powered. http://www.voith.com/en/products-services/power-transmission/voith-inline-thruster-voith-inline-propeller-11014.html (watch the "installation" video). Also, this video explains the concept a bit (for maritime applications)
I suppose if you could arrange a lightweight frictionless magnetic ring bearing (possibly integrating electric drive), and/or peripheral drive linking system, it might be worth it if you needed to have two or three smaller fans beside each other, driven by a single core, rather than a singe large fan, in order to reduce fan/nacelle height. (imagine a B52 nacelle with one side shortened to just a fan cowling) I doubt that this would reduce overall drag, though, but I am intrigued by the concept of the greatest chord of the blades travelling the fastest.
You're thinking of an exoskeletal engine. They've been studied, and have lots of theoretical advantages, but the major sticking point that's kept them from being used so far is that we don't currently know how to make bearings suitable for supporting the large spinning rotor drum.
