Do multi engines face the torque effect? What about jets?
    $\begingroup$ By "torque effect" do you mean p-factor? Or some kind of rolling effect due to a high power engine? $\endgroup$
    – Ron Beyer
    May 14, 2017 at 1:36
    $\begingroup$ @RonBeyer to be fair, if the OP understand the difference between torque and p-factor, he would not be asking this question. $\endgroup$
    – kevin
    May 14, 2017 at 12:20
  • $\begingroup$ I know that the torque effect is the left-turning tendency an aircraft has. Don't know what p-factor is (the Wikipedia explanation is a bit complicated). Any videos? $\endgroup$
    – TayE
    May 14, 2017 at 13:11
  • $\begingroup$ With all engines operating or one or more engines inoperative? $\endgroup$
    – J W
    May 16, 2017 at 17:16
Maybe you mean the p-factor. If both engines are rotating clockwise, the plane yaws to the right. If one rotates clockwise, the other counter-clockwise, the effect cancelles out and the plane flys straight.
  • $\begingroup$ What about the effect of the two engines operating at different speeds? Is that significant? $\endgroup$ May 20, 2017 at 23:16
    $\begingroup$ @TannerSwett I think so. The p-factor is directly proportional with the speed of the prop. Now, if one engine operates at a different speed, the plane will yaw into the direction of the faster engine. (Apart from the fact that the thrust is applied asymmetrically) $\endgroup$ May 22, 2017 at 15:22
