I already have private pilot for single engine land with instrument and commercial ratings.
Since you didn't specify the type of Airship you're looking to get a rating in, I found a Flight Standardization Board (FSB) Report for a Zeppelin, that discusses the training required for that specific Airship.
Here is the relevant time requirements for this particular airship from the document:
5.2 Commercial Airship Pilot
(a) Ab Initio:
Standard duration of training: Approximately 20 months
Maximum duration of training: 24 months
Theoretical training: 300 hours
Practical training: Three months on a ground crew
Minimum of 50 training flight hours
Minimum of 150 supervised flight hours
(b) Students holding a CPL:
Standard duration of training: Approximately 15 months
Maximum duration of training: N/A
Theoretical training: Minimum of 93 hours
Minimum of 40 training flight hours
Minimum of 130 supervised flight hours
(c) Type Rating:
Standard duration of training: Approximately four months
Theoretical training: Minimum of 49 hours
Practical training: Minimum of 25 training flight hours
Minimum of 100 supervised flight hours
The Commercial Practical Test Standards for Lighter-than-Air can be found on the FAA Website, and you would need to make sure that you had satisfied the following conditions:
An applicant already holding a commercial pilot certificate who applies for an additional category and/or class rating on that certificate must:
  1. hold a commercial pilot certificate;
  2. have the prescribed aeronautical experience and training required for the category and class rating sought;
  3. pass an additional knowledge test for the rating sought (unless already rated in airplane, rotorcraft, or airship) since the beginning of the 24th month before the month in which he/she takes the practical test; and
  4. obtain an endorsement from an authorized instructor certifying that the applicant has been given flight instruction in the applicable AREAS OF OPERATION listed in 14 CFR part 61, section 61.127, for the commercial pilot rating sought in preparation for the practical test within 60 days preceding the date of application. The statement shall also state that the instructor finds the applicant competent to pass the practical test, and that the applicant has satisfactory knowledge of the subject area(s) in which a deficiency was indicated on the knowledge test report.
So you can see the standard duration of training is approximately 15 months. There are some interesting anecdotes in this article from AOPA:
Pilots interested in getting their pilot certificate with an airship rating will have to train while on the job, since there are no schools that teach this particular skill, according to Bret Viets, chief pilot on the MetLife Snoopy Two blimp.
Veits goes on to say that it took him 66 days. (He started Dec 4, 2007 and took his checkride on Feb 8, 2008). And he thought he did in a pretty short time period. It sounds like he got lucky and ended up having the airship to himself for training for a couple weeks!
Looks like you're on your way with a commercial rating, too:
The company prefers that applicants have a commercial rating, whether it’s on airplanes, helicopters, gliders, or hot air balloons, said Viets. “It just makes the transition to airship hourly requirements less if someone already has a commercial rating,” he said. “To transition to airships is a minimum of 50 hours, but it usually takes a little longer than that, like any aircraft rating.”
If an applicant does not have a commercial rating, he or she will need 250 hours in airships before getting that commercial airship rating, said Viets. “They prefer pilots with 1,200 hours and a CFI certificate,” he said.
  • $\begingroup$ Another (more recent) anecdote: Embry-Riddle's Alumni Magazine Lift had a feature in the Fall 2017 Edition (lift.erau.edu/flying-into-the-wind) where an Alumnus mentioned that it took him 9 months to earn his Airship rating. $\endgroup$
    – Canuk
    Sep 29, 2017 at 23:51
