On aircraft with an ACM air conditioning, where does the final cooling take place? Is it in the ACM expansion turbine or in the ACM compressor?
$\begingroup$ Specifically, please elaborate on what kind of air conditioning system you're referring to. Are we talking about airliners here? Single-engine pistons? $\endgroup$ – reirab May 2 '17 at 16:05
$\begingroup$ Yes,it is about jet engine a/c $\endgroup$ – Komail Mohamed May 2 '17 at 16:13
3$\begingroup$ Related, the different temperatures in the a/c system. The last cooling occurs at the turbine stage. From this answer. $\endgroup$ – mins May 2 '17 at 18:11
$\begingroup$ Related: aviation.stackexchange.com/a/13321/4108 $\endgroup$ – Sanchises May 4 '17 at 8:11
