How should a load controller state additional lashing equipment on a load sheet in the context of ULDs? Should the additional weight equipment be added to the ULD's contents, or added to the ULD tare weight? Listing the additional equipment as Equipment In Compartment (EIC) does not seem to be a possibility.
    $\begingroup$ Is this a test question to which you're trying to find the answer? Please explain what work have you done to attempt to answer this yourself, since "do my homework for me" questions tend to be very poorly received here. Also, please don't use all capitals in your question, as that is also poorly received here (as it is nearly everywhere on the internet). $\endgroup$
    – Ralph J
    May 1 '17 at 2:47
  • $\begingroup$ i glanced all AHM , if you have any reference will be accepted with wellcome. $\endgroup$
    – bbahceci
    May 1 '17 at 3:26
    $\begingroup$ To be rude to the person who tries to help you is guaranteed to get you a bad reception. If you took even 20 seconds to view Ralph's profile, you should see that he is a highly respected member of this community. You might also learn something that would help you. Good bye. $\endgroup$
    – Simon
    May 1 '17 at 6:17
    $\begingroup$ People seem to be reading a lot into a little here. The last sentence of the question is vague - especially in the original, pre-edit version - and it doesn't seem like an obvious test question to me. Furthermore, if that last sentence weren't there, how would the question be received? I suspect that people would be trying to answer it rather than assuming that the OP is trying to pass a test. But even if s/he is, the current balance of meta opinion is on the side of answering. $\endgroup$
    – Pondlife
    May 1 '17 at 12:19
    $\begingroup$ I would second Pondlife's comments. I would be slow to read too much into anything the OP has said here, since there does appear to be a language barrier, which I am quite sympathetic toward. I think it sounds like a good question. I don't know much about the subject of ULDs, so if anyone more knowledgeable can improve my cleanup attempt please do! @TomMcW, does this fall anywhere near your scope of experience? $\endgroup$
    – J Walters
    May 1 '17 at 13:45
Normally I would put this as a comment since I retired in 1999, and I don't know what current practice is. However, this is a bit too long for a comment. Also, this is from memory and it's been a long time now, as it's from my experience with load sheet preparation in the late 1980s and the 1990s. If a more recent useful answer appears, I'll simply delete this.
Further, this answer only directly addresses the question's last sentence:
The airplane does not, of course, care whether the extra lashing weight is tare weight or content weight. What it cares about is the total weight at the ULD position, and that's what the weight & balance calculations (probably done by computer) will use, whether given as one value or two values (tare & content) that have to be added.
Just adding the extra weight to a compartment without specifying where in the compartment it is would effectively put it wherever the compartment centroid was. That would be correct only if the ULD happened to be at that position.
In actual practice it could be argued that just adding to a compartment rather than a position in that compartment would be acceptable in some instances. For example, let's say you're very close to max takeoff weight before the addition, but the c.g. is well within limits. The ULD locations would have been decided by the software (or manually by the loadmaster) to put the c.g. nowhere near the limits. Adding a few pounds of extra lashing might put you over max takeoff, but it's going to make little difference to the c.g.
All of the three cargo carriers I was involved with insofar as weight & balance were concerned simply listed the total weight at a position. No differentiation was made between tare and cargo. Thus the addition of extra lashing was simply added to that positions weight, usually by rerunning the software to get a new solution.
The most common reason I observed for adding extra lashing was that when loading the ULD to a position, they found that one or more of the floor locks to hold the ULD in position were broken. For such cases, the loading manuals specified how many locks could be inoperative and how much extra lashing there had to be. Frankly, that extra weight was often ignored, but it was sometimes accounted for.
I don't have a definitive answer as to whether extra lashing should be added to tare or content. That is irrelevant to the airplane, though I can well imagine that there might be a form somewhere that required such a split. If someone had asked me back when I working which it should be, I would have said that it should be added to the tare for the simple reason that the ULD is there to safely contain the content. If for some reason extra containment weight had to be added to make the ULD safe, that would seem to be tare weight to me.
And I imagine that a customer, who had paid money for a certain amount of weight to be shipped, found out that because of broken parts on the airplane he had to pay more, he would not be happy.
A thorough search of the weight & balance manuals for aircraft might yield additional relevant information. Some such manuals for 747s and 767s can be found at http://terryliittschwager.com/wbmanuals.php
