If a glider has a safe normal landing in a cow pasture or other farm field and has no damage, how is it typically recovered to be returned to an airport for a future flight? Are the wings designed for quick/easy removal and the wings and fuselage are just hand-carried to a long trailer waiting on a nearby road? That's kind of how it's done (I believe) with balloon landings, but not sure what the process is for gliders.
2$\begingroup$ FYI Usually glider pilots plan their flights so that they are always in range of an airport. Field landings are pretty rare. $\endgroup$ – Tyler Durden Apr 28 '17 at 20:03
6$\begingroup$ @TylerDurden For XC flights field landings are very common. Yesterday eleven gliders took off at my airfield and seven of them had field landings. We don't plan to be in airport range but in "field range". In regions like the Alps there are even "field landing catalogs" which people use to plan their flights. $\endgroup$ – Gypaets Apr 28 '17 at 21:11
$\begingroup$ @Gypaets Maybe in rural Switzerland that works, but landing outfield in New England 70% of the time would be a life-limiting course of action. $\endgroup$ – Tyler Durden Apr 28 '17 at 22:56
5$\begingroup$ @TylerDurden: there are of course places where outlandings are complicated, and maybe New England is one of those. But in the vast majority of places where gliders are flown, outlandings are possible, and common. Definitely not rare. I have personally outlanded many times, and have done even more retrieves of other pilots; both in club flying, and in competitions. Of my 30+ outlandings, as far as I can remember only one was at an airport. $\endgroup$ – Martin Argerami Apr 29 '17 at 3:25
All gliders can be disassembled to take off wings and elevator.
For each glider type there is a car trailer into which the glider fits after disassembling.
Here you see the “reverse” process (assembly):
$\begingroup$ In our club, before every cross-country flight, a "pick-up" party is appointed and "paid" in the local bar if the service is needed $\endgroup$ – gusto2 May 8 '17 at 14:23
Trailering is the most common, however at some of our club's select off airport spots, we had landowner's permission, and I would land the Pawnee and the crew with the trailer would show up for a launch. It saves the time of disassembly and reassembly. But for most glider pilots the norm for an off-airport landing is to trailer the craft to the airport.
