If I want to design an aircraft that can fly with high speed while loaded, which tail type should I choose.
The mission is to design an aircraft that can move a certain distance with high speed while carrying certain load.
    $\begingroup$ What does "high speed" mean? Supersonic? Transonic? Hypersonic? 200kts? $\endgroup$
    – Ron Beyer
    Apr 17, 2017 at 13:33
    $\begingroup$ Every single aircraft can transfer some load some distance at some speed. Presumably. $\endgroup$
    – Steve
    Apr 17, 2017 at 16:50
Lose the tail.
By Staff Sgt. Bennie J. Davis III [Public domain], via Wikimedia Commons
  1. Split brake-rudders will do the trick.
  2. You can also try and beat NASA and Boeing to the Active Flow Control tails.
  3. Or just settle for a T-tail.
The horizontal tail plate effectively increases the aspect ratio of the fin by virtue of the 'end plate' effect. The T-tail configuration is especially popular on gliders.
(Flight 1977—PDF) Early Boeing 757/767 designs featured T-tails to reduce drag.
  • $\begingroup$ Thanks a lot :) I was hesitated about T-tail and conventional tail ,I'll choose T-tail then $\endgroup$
    – mariam
    Apr 17, 2017 at 14:57
