Early on in training I was told that unless the airport specifically noted it on the chart, that the transponder was turned to ALT (altitude) mode just prior to taking the runway for take-off (lights, camera, action), and was changed back to SBY (standby) immediately after exiting the runway.
Recently we had a Garmin GTX-345 ADS-B transponder installed in our aircraft and as part of the ADS-B rebate program you need to do a check-out in "rule airspace". When I got the test report from the FAA I noticed that I passed the air portion but failed the ground portion due to an insufficient number of reports (messages) while on the ground. I retook the test making sure to put the transponder in ALT mode at the hangar and subsequently passed.
This leads me to believe that the transponder should be in ALT mode pretty much all the time. Is there any recommendations from the FAA that say that ADS-B transponders should be active while on the ground?
The GTX-345 Manual (2-1) has this to say:
The transponder system no longer supports a pilot selectable GND mode. The transponder should always be in ALT mode prior to moving on the airport surface. It must be in ALT mode when operating in certain controlled airspace, in accordance with 14 CFR 91.215. For guidance on transponder operation, refer to the FAA Aeronautical Information Manual (AIM), 4-1-20(a)(3)
(Emphasis mine)
Is this backed up by the FAA?
  • $\begingroup$ @RalphJ Actually, no. The answer is the same and it doesn't matter if you have ADS-B or not. The transponder should be on and in ALT mode on while taxiing regardless. Ron even starts off his question telling us how he was taught (which is now superseded with new guidance) and his quote references the same guidance that applies to both. $\endgroup$ – Lnafziger Apr 14 '17 at 18:39
Yes, it's in the the AIM 4-1-20:
3. Transponder and ADS-B operations on the ground. Civil and military aircraft should operate with the transponder in the altitude reporting mode (consult the aircraft’s flight manual to determine the specific transponder position to enable altitude reporting) and ADS-B Out transmissions enabled (if equipped) at all airports, any time the aircraft is positioned on any portion of an airport movement area. This includes all defined taxiways and runways.
| improve this answer | |
  • $\begingroup$ I wonder though if this is meant to clarify 91.215, the AIM as far as I know is not regulatory but advisory in nature. $\endgroup$ – Ron Beyer Apr 14 '17 at 16:14
    $\begingroup$ @RonBeyer Well, you did ask for "recommendations" from the FAA :-) $\endgroup$ – Pondlife Apr 14 '17 at 16:25
  • $\begingroup$ I'd upvote the answer again just for that comment if I could :). 92.215 reads like all transponders must be in ALT mode while operating on the surface, which leads me to think that my training was incorrect in having it in SBY during taxi, but then again why would an airport like MKE have a comment that reads like this: ASDE-X IN USE. OPERATE TRANSPONDERS WITH ALTITUDE REPORTING MODE AND ADS-B (IF EQUIPPED) ENABLED ON ALL TWYS AND RYS.? $\endgroup$ – Ron Beyer Apr 14 '17 at 16:32
    $\begingroup$ @RonBeyer This recommendation changed recently (maybe two years ago?) to what is in the AIM now, which is probably why you were taught differently. The GTX manual even gave you the reference that Pondlife quoted for you. :) $\endgroup$ – Lnafziger Apr 14 '17 at 16:59
    $\begingroup$ Back in 2015, the FAA published a SAFO advising pilots to have transponders in altitude reporting mode whenever their aircraft is on an airport movement area at ALL airports, to ensure proper reporting at any airports equiped with ASDE-X or A-SMGCS: faa.gov/other_visit/aviation_industry/airline_operators/… $\endgroup$ – newmanth Apr 14 '17 at 21:41
