32
Evacuation procedures after a forced landing recommend directing passengers upwind of the aircraft.
What is the reason why evacuating upwind is better than other directions?
  • 31
    $\begingroup$ Which way will the smoke and fire blow? $\endgroup$
    – Simon
    Apr 14 '17 at 10:50
47
There are two problems linked to the wind after accidents:
  • Inflating the slides.
  • Running away from the aircraft when on the ground
@DavidRicherby listed the reasons related to running away upwind to try to avoid the effects of flames and fumes (visibility, heat, toxicity). This is part of the IATA guidelines for post-evacuation:
Post-evacuation. Once outside the aircraft, the cabin crew is responsible for the passengers until relieved by the authorities or emergency services. Until this help arrives, the cabin crew should:
- Direct passengers upwind and away from the aircraft;
- Assemble passengers;
- Direct passengers away from fuel, fire and vehicles;
Source
While it appears running upwind is a good choice, deploying slides upwind has not always been a good idea.
A study was conducted by the National Aerospace Laboratory (NLR) in Netherlands, about slides issues during evacuation. It was published by the Flight Safety Foundation in 2005:
The scope of the search was the period 1970–2003 and covered aircraft operations worldwide. NLR researchers identified 150 accidents in which slides were used. A total of 89 slide problems were identified:
One problem was slides not inflating due to the wind:
Wind had an adverse effect on the use of slides in 11 slide problems (12.4 percent) analyzed by NLR researchers. Typically, wind blew the slide against the side of the aircraft, preventing its use.
To allow using the upwind side of the cabin for slide deployment, today, aircraft certification include this requirement for slides:
4.20 Wind. The device must be shown, in 25-knot winds directed from the most critical angle, to deploy and, with the assistance of only one person who has evacuated down the device, to remain usable after full deployment to evacuate occupants safely to the ground.
Source
See also:
40
If there is a fire, any smoke and flames will blow downwind. If there is a fuel leak, the fuel vapours will be blown downwind, risking a fire or explosion there and potentially making it hard to breathe.
The evacuation at least 500 meters upwind is to prevent from being intoxicated with toxic fumes, gases from burning materials and alike
    $\begingroup$ This answer adds nothing significant to the existing answers. $\endgroup$ Jun 21 '17 at 17:13
