I read that the intake mass flow ratio (not sure its translated to correct lingo) can be expressed as:
$C_A = \frac{\textrm{airflow through air intake}}{\textrm{air density } \times \textrm{ speed of free flow }\times \textrm{ intake area}}$
A graph of this could look like:
Air intake factor
Now my question is two fold:
  1. What is the correct english term for this factor?
  2. How do I estimate how much air flows through the intake due to engine suction.
  • $\begingroup$ Maybe the term is more like inflow-number. Don't know. If for example flying at low speed and more air is sucked in that would normally hit the intake if it was only a tube, then the airintake factor is greater than 1. That how I understood it. $\endgroup$
    – Invariant
    Apr 10, 2017 at 2:44
Okay, to solve this I assumed the atmospahere is ISA and flying at 0ft. Also that air suction vary linear proportional to mil thrust.
So that airflowThroughAirIntake = factor*thrust
I then did some flight tests to estimate what that factor would be, getting the ratio from the graph at full mil thrust.
