10
I was watching the following video of the Russian Knights and Swifts aerobatic teams flying together in formation. The contrast in the size of their airplanes is striking.
Why was the Su-27 designed to be so much larger than the MiG-29?
Do the two planes have very different missions?
20
The Su-27 and Mig-29 were the result of high-low concept subscribed by both the USAF and Soviet Air Force (VVS) in the 1970s. Basically, this involved the development of two different fighters, a high performance medium weight fighter crammed with every advanced technology (which made it expensive) and a low cost light weight fighter to make up the numbers.
In this direction, the USAF announced the FX (Fighter eXperimental) program, which resulted in the McDonnell Douglas F-15 Eagle (designed to counter the misunderstood Mig-25), followed by the LWF (Light Weight Fighter) competition, that gave birth to the General Dynamics F-16 Fighting Falcon.
The Soviet equivalent of these programs was the PFI( Perspektivnyi Frontovoy Istrebitel, Perspective Frontline Fighter), which called for a high performance multirole aircraft to counter the new generation US aircraft and the LFI (Lyogkiy Frontovoy Istrebitel, Light Frontline Fighter), which called for a low cost fighter with respectable ground attack capabilities.
The PFI was required to operate 250-300 km beyond the frontline, with sizeable internal fuel and a comprehensive Communications, navigation, avionics and weapons suite. The LFI, on the other hand was required to operate 100-150 km beyound the frontline, while being easy (read cheap) to build and maintain and capable of using semi-prepared strips while carrying limited armament (initially limited to a couple of medium range AAMs and gun).
In 1972, the VVS tasked the Sukhoi bureau to build the PFI, resulting in the Sukhoi Su-27, while the Mikoyan bureau got the LFI, resulting in Mikoyan MiG-29.
F-15 and F-16
F-15 and F-16; image from sunketh.wordpress.com
Basically, Su-27 is to Mig-29 what F-15 is to F-16; hence the size difference.
    $\begingroup$ This is an interesting perspective, comparing the US and the Soviet solution to basically the same problem. Your answer highlights the different approaches taken by the Americans and the Soviets. While the US developed two very different planes, the Soviets more or less went for a scaled solution, since the MiG 29 and the Su 27 share their aerodynamic layout. $\endgroup$
    – Dohn Joe
    Apr 7, 2017 at 7:31
The Su-27 was design to fly escort for long distance bombers, whereas, the Mig-29 was designed for front line action. This distinction in the primary mission of the two aircrafts becomes apparent when you look e.g. at the range.
More fuel means more weight, means more powerful engines, means more fuel, etc.
