I use to fly a very light plane, with a 100-hp engine. In order to calculate the power needed by a similar plane, but 50% larger, I reason as follows:
In general, the power required by an airplane is proportional to its weight times its speed. The weight scales with the cube of the linear dimension, so the larger plane would weigh 1.5 cubed = 3.375 times more. Since the airspeed is squared in the formula for lift, the exponent for the proportionality of lift should be 1/2.
I have now two exponents for the scaling, 3 for the weight (or mass, in this case) and 1/2 for the speed. As the weight and speed are multiplied in order to get the proportionality of the power required, I add the exponents, and the result is that the larger plane would need an engine of 1.5 ^ 3.5 = 4.13 x 100 = 413 hp.
Is this OK?
