Which airlines can be designated as "major"? what difference between them and other airlines?
What qualities airline should have to be "major"?
I can't find any proper description, but I heard about it a lot from aviation news.
$\begingroup$ Perhaps we should start by defining what an airline is, much less a major one. $\endgroup$ – J Walters Mar 19 '17 at 9:16
Unofficial Terminology
In the United States, the unofficial term Major Airline
is likely based on various official FAA and DOT terms. I cannot speak to use of the term outside the United States, but it may be similar, if used at all. This answer will address use in the context of US law and FAA regulations.
If a definition of Major Airline
is to be faithful to official sources, that definition could be one such as the following from BusinessDictionary.com:
US designation for an air carrier with annual operating revenue of more than one billion dollars, such as American, Northwest, and United Airlines. Also called major carrier.
However, as voretaq7 pointed out, the term Major Airline
can be used to refer to the traditional "Legacy Carriers"—as opposed to newer start up carriers, the "Regionals", or low cost carriers. The terms are sometimes used interchangeably.
Official Terminology
The official terminology from which Major Airline
is likely derived has a regulatory basis in 14 CFR 241, Section 4, "Air Carrier Groupings". This section describes the basis for grouping of Large Certificated Air Carriers, and defines the various groups. The following gives the criteria for assessing the level of operations (note that the nature of operations is assessed separately):
(a) All large certificated air carriers1 are placed into three basic air carrier groupings based upon their level of operations and the nature of these operations. In order to determine the level of operations, total operating revenues for a twelve-month period are used. The following operating revenue ranges are used to establish air carrier groupings:
Carrier Group Total Annual Operating Revenues I 0-$100,000,000 II $100,000,001-$1,000,000,000 III $1,000,000,001 +
The DOT's Bureau of Transportation Statistics provides the following similar, but simplified, definition of Major Carrier Group:
Major Carrier Group: Air carrier groups with annual operating revenues exceeding $1,000,000,000.
Answer
Thus, to answer your question as to what is required for a US "airline" to be designated as "Major" in an official capacity, the "airline" must:
- Be a Large Certificated Air Carrier (see definition below), and
- Have a reported annual revenue of more than $1,000,000,000.
Definitions
The following are definitions as given in 14 CFR 241, Section 3, "Definitions":
1Large Certificated Air Carrier:
An air carrier2 holding a certificate issued under 49 U.S.C. 41102, as amended, that: (1) Operates aircraft designed to have a maximum passenger capacity of more than 60 seats or a maximum payload capacity of more than 18,000 pounds; or (2) conducts operations where one or both terminals of a flight stage are outside the 50 states of the United States, the District of Columbia, the Commonwealth of Puerto Rico and the U.S. Virgin Islands.
2Air Carrier:
Any citizen of the United States who undertakes, whether directly or indirectly or by a lease or any other arrangement, to engage in air transportation3.
3 Air transportation:
The carriage by aircraft of persons, property, or mail.
In the US "Major Airline" is a DoT designation that refers to airlines (Part 121 carriers) with over $1Billion in annual revenue.
It is distinct from "legacy carriers" - the ones that existed prior to airline deregulation in 1978 - though the legacy carriers tend to be major airlines (American, United, Delta, Hawaii Airlines, and Alaska Airlines are all "Major Airlines") and the terms are often used interchangeably.
1$\begingroup$ Is this term used in the world, not only in US? $\endgroup$ – wiaim Mar 17 '17 at 12:54
1$\begingroup$ @wiaim I'm sure other countries use the term - or its equivalent - but I can't speak to what their official definition of the term is (or if they even have one - it may be used as an informal term in other countries with a meaning akin to "Airline whose name everyone recognizes from TV ads"). $\endgroup$ – voretaq7 Mar 17 '17 at 13:07
$\begingroup$ I don't think I agree with this answer as worded. The DOT seems to use the term "Majors" or "Major Group" to refer to Group III air carriers designated under 14 CFR 241 Section 4. As far as I can tell the colloquialism "Major Airline" is based on these designations, but has no official status. $\endgroup$ – J Walters Mar 20 '17 at 16:42
