The context of the work: in an ATC model, we currently have a graph model to set the routes for different aircraft. We want to improve its precision by generating more nodes for each route and in order for these nodes to be feasible (i.e., reachable by the aircraft) you do that embedding the Dynamics of the vehicle in the generation of nodes.
Bottom line, I need some "citable" source where I can find the values for the minimum turning radius of an airplane. Since it is preferrable to be conservative than to implement something that cannot be done, I am looking for "large" commercial aircraft as I understand they will set an upper bound. That said, it is a research work so it doesn't need to be "the largest aircraft that ever cruised over the airspace", just some reasonably big airplane that is commonly used: Boeing 747, Airbus A380,etc..
Note: only Civilian flights are considered, therefore military crafts are not relevant here
