How did the "wet takeoff" of old days work? Was the water used ordinary distilled water, or did it have additives? Where is it carried in the aircraft?
2$\begingroup$ What are "leaky jets"? You mean the water injectors? $\endgroup$ – Ron Beyer Mar 10 '17 at 15:52
2$\begingroup$ Related discussion of water injection, although not really a duplicate as it addresses some aspects of water injection, but in the context of injection vs contamination. This question asks for a more complete treatment of the topic than what is presented there. $\endgroup$ – Ralph J Mar 10 '17 at 16:27
1$\begingroup$ "Leaky jet" is reference to low and very low bypass turbofans, like the JT8. Water injection and leaky jets kind of shared the same technological age, that's why they relate to each other. $\endgroup$ – Germano Cavalcanti Mar 12 '17 at 13:13
$\begingroup$ @GermanoCavalcanti: Early 747-100s also used water injection, despite their high-bypass engines. $\endgroup$ – Vikki - formerly Sean Sep 1 '19 at 2:56
On many early jet airliners water was sprayed it into the engine air intake or compressor where evaporation cooled the air and allowed cooler, denser air to be ingested by the engine. The result was increased thrust, especially needed for operation from hot and high airfields, or a cooler temperature in the hot section of the engine at the same thrust. From SAE Paper Number 2004-01-3108:
Water injection was first used over 45 years ago on commercial transport aircraft to increase thrust. Boeing 707-120 aircraft with Pratt & Whitney JT3C-6 engines and later, the Boeing 747-100 & 200 aircraft with Pratt & Whitney JT9D-3AW and -7AW engines, all used water injection for thrust augmentation.
This report discusses various techniques for water injection:
- ahead of the low pressure compressor. This is the common method for thrust increase in hot and high conditions.
- ahead of the high pressure turbine. This is used in cold weather, when injection ahead of the low pressure compressor would run the risk of ice accretion.
- together with fuel into the combustor. This technique is commonly used with stationary gas turbines in order to reduce nitrogen oxide emissions.
And NASA-TM-2010-213179 is more specific on the system:
Four water-injected Pratt & Whitney JT3C–6 engines were used on early Boeing 707–120 Stratoliner aircraft to augment takeoff thrust on days above 20 °F. This system used a belly tank to store demineralized water and an electrically driven boost pump to deliver water to the four engines. At that point, an engine-driven mechanical pump increased the pressure to about 400 psi for injection before the low-pressure compressor (LPC) on days as cold as or colder than 40 °F and for injection into the high-pressure compressor (HPC) only on days between 40 and 20 °F.
What would happen if kerosene instead of water was filled into the water tanks was tried out by a BAC-111 on September 6, 1971:
The aircraft collided with a bridge, shearing off both wings, after a double engine failure occurred during takeoff. The water-injection system to cool the engines during takeoff was inadvertently filled with kerosene instead of water.
More recent work on water injection focused on the reduction of nitrogen oxides which form in lean combustion and high temperature. By lowering the temperature level of the combustion process, the nitrogen oxide pollution can be greatly reduced.
$\begingroup$ How did the kerosene injection cause the engines to flame out? I have a hard time picturing how that would work... if water is okay to put into the engine at that point, why is a little more fuel a bad thing? $\endgroup$ – Ralph J Mar 11 '17 at 22:02
$\begingroup$ @RalphJ Reports say they noted an increase in engine temp during the takeoff roll. Injecting fuel in the compressor stages ahead of the burners would almost certainly result in early combustion and surge. $\endgroup$ – TomMcW Mar 12 '17 at 4:50
2$\begingroup$ Extra fuel probably raised the temperature above material capacity; at some point the pieces might had melt and changed their shape and center of mass, colliding with other parts or vibrating the system to a fail point. $\endgroup$ – Germano Cavalcanti Mar 12 '17 at 14:07
2$\begingroup$ I've gone ahead and changed your date from June 9 to September 6. It's given as "9/06/1971" in the page you link, which seems to use mm/dd/yyyy dates; see also Paninternational Flight 112 on Wikipedia. $\endgroup$ – Terran Swett Jul 15 '19 at 13:15
I offer this as an adjunct to Peter Kämpf's answer above. The simple explanation is that the injected water evaporates during the compression stages, and this cools the air (think sweat evaporating cooling your skin on a hot day).
Short answer
Water injection gives the jet engine the ability to do more work for a short time without exceeding the design limitations of the engine in extreme conditions.
Turbine engineering
Jet engines were / are designed and built to specifications and tolerances based on the materials used. The "design thrust" is usually the static thrust the engine is capable of given standard conditions (i.e. static air temperature, atmospheric pressure, humidity, etc.). But when it's hot outside, the design thrust is sometimes insufficient for the aircraft weight / runway length / wind conditions, etc., and airlines don't like having to bump pax / cargo off the plane for being unable to get airbornea. Water injection is a method to mitigate this scenario.
Physics of how injecting water gives more thrust
Understanding the ideal gas law, $PV = nRT$, is key to this discussion. As Peter stated, by cooling the air ($\downarrow T$), then something on the left side of the equation also has to decrease. ($R$ is a constant.) This has to be pressure ($P$), as the volume ($V$) inside the combustion chamber doesn't change (at least we'd hope it doesn't!).
But here's a twist: Adding water vapor to air lowers its density. Since density is mass (number of molecules $n$) divided by volume $V$, and again, the volume isn't changing, then this implies $\downarrow\!n$b. Now, we have $\downarrow\!PV = \downarrow\!nR\downarrow\!T$.
So, how do we increase the density to the air coming into the hot section as Peter mentioned?
Water injection $\Rightarrow$ burn more fuel
To increase density, one needs to cram more molecules into the given volume. The only way to do that in an internal combustion turbine is to increase the fuel flow, thereby increasing the intensity of the combustion process, and causing more air to be sucked into the hot section. The water injection merely gives the engine the ability to do more work without exceeding the tolerances of the engine in extreme conditions.
Note that the water injected has completely evaporated into vapor prior to reaching the hot section. While the water molecules don't contribute to the combustion process (obviously), there isn't so much of it to hamper it, either.
The "water injection era"
I sometimes think water injection was merely an engineering "hack" to help bridge the technology gap between the large, modern airframes of that era, and the puny engines used to fly them.
Granted, metal airframe construction dates to the late 1920's, and jet engines didn't appear until around 15 years later. So, by the late 1950's, airframes were modern and state-of-the-art, but jet engine technology was severly lackingc.
The military dealt with this by bolting on more and more enginesd,e. However, this was impractical for commercial airline service, so any available engineering "trick" had to be employed to accommodate the newer airliners.
Finally...
Lest I get flamed to a crisp for the above invective, let me just say that the "water injection era" needed to happen. Think about it: the Boeing 747 was the worst thing and the best thing to happen to jet engine development. The modern turbine engines these days are engineered for the "extreme" conditions mentioned above (no need for water injection), and cool gadgets like FADEC help keep them running clean and efficiently.
a But, airliner manufacturers do like to advertise the capabilities of their products (as do jet engine manufacturers). I mention this in particular because it seems that the 1960's and early 1970's saw a big increase in promoting air travel on a cultural and societal level yet it seemed as if the technology couldn't keep pace.
b Actually, the number of molecules isn't changing so much as the average molecular weight of all the molecules. Again, see this link for more info.
c I base this assertion on how the Boeing 747 program was delayed repeatedly because of problems with the JT9D development.
d and water injection. Note that I intentionally leave out afterburning as a "trick" in this context as it is often used in multiple stages of flight--i.e. it's not a one-time-use only procedure.
3$\begingroup$ You seem to be saying that the military's response to underpowered engines was to use more of them, and the civilian response was to use water injection. The military made extensive use of water injection. $\endgroup$ – David Richerby Mar 12 '17 at 10:13
$\begingroup$ @DavidRicherby: thanks for the feedback; perhaps I was unclear about that. I am aware of the military use of water injection... But, my point still stands that a whole bunch of little engines for a commercial airliner doesn't make much practical sense. $\endgroup$ – pr1268 Mar 12 '17 at 12:36
2$\begingroup$ Thank you, @pr1268; your answer was indeed a nice supplementation covering additional aspects about this topic. $\endgroup$ – Germano Cavalcanti Mar 19 '17 at 12:43
Water injection is used on the Rolls-Royce Pegasus engine on the Harrier jump jet, but it has nothing to do with combustion. Instead, water is injected to cool the turbine blades to temperatures that allow the engine to operate at full rated power.
The maximum take-off thrust available from the Pegasus engine is limited, particularly at the higher ambient temperatures, by the turbine blade temperature. As this temperature cannot reliably be measured, the operating limits are determined by jet pipe temperature. To enable the engine speed and hence thrust to be increased for take-off, water is sprayed into the combustion chamber and turbine to keep the blade temperature down to an acceptable level.
Water for the injection system is contained in a tank located between the bifurcated section of the rear (hot) exhaust duct. The tank contains up to 500 lb (227 kg, 50 imperial gallons) of distilled water. Water flow rate for the required turbine temperature reduction is approximately 35gpm (imperial gallons per minute) for a maximum duration of approximately 90 seconds. The quantity of water carried is sufficient for and appropriate to the particular operational role of the aircraft.
Selection of water injection engine ratings (Lift Wet/Short Lift Wet) results in an increase in the engine speed and jet pipe temperature limits beyond the respective dry (non-injected) ratings (Lift Dry/Short Lift Dry). Upon exhausting the available water supply in the tank, the limits are reset to the 'dry' levels. A warning light in the cockpit provides advance warning of water depletion to the pilot.
If you run out of water on a Harrier, you will have serious problems trying to keep the engine from frying itself in anything other than conventional flight. No VTOL after that.
This is really pretty much another supplement to Peter Kampf's answer, trying to clarify part of the answer that I found a bit unclear. Specifically, he quotes a section saying:
At least to me, those temperature ranges don't seem to make a whole lot of sense.
At least according to the KC-135 flight manual (T.O. 1C-135(K)A-1) you used dry thrust below 20F, injected heated water between 20 and 40 F, and unheated water between 40F and 100F.
For those interested in the nitty-gritty details:
The injection of water ahead of the combustion chambers will cool the airflow, thereby increasing it's density and potentially allowing more fuel to be burned, increasing power. Water injection ahead of the high pressure turbine will have the effect of cooling the turbine, which may permit use of a higher power setting, and the mass of the water will be added to the mass flow rate through the engine, directly increasing thrust.
water molecules do contribute in the combustion process, since in the turbine the temperatures and pressures reach the thermolytic ratio for water ignition. At 1 bar that temperature is 5600C. At elevated pressures, the temperature is reduced subsequently, since volume remains the same, by n is increased relatively. At BAC-111 the crash incident was due to luck of thrust since no water spray was made available.
1$\begingroup$ The 6 September 1971 BAC-111 crash? Wikipedia says it was caused by jet fuel in the water injection system, quite different from what you write. Also, could you elaborate on how exactly does "water ignition" [sic] work? What exactly would be oxidized in this reaction? $\endgroup$ – AEhere supports Monica Jul 15 '19 at 9:09
