11
Recently Airbus presented its lastest projects A330neo and A320neo.
I'm sincerely surprised about the cockpit, in that it is essentially the same of the original A330, while I was expecting that renovation would affect not only the engines, installations, and lights but also the cockpit instrumentation taking inspiration from the new bigger screens of the A350.
I know that in this way the training for pilots is much easier, but at the same time I think that if a new cockpit is developed for a new plane (taking into consideration that "Type Rating" is anyway considered the same), it should be because of more safety, readability, and situational awareness.
In the past Boeing completely updated its cockpit inside the B747-400 and B737NG models from the original mechanical/analog gauges to the new glass cockpit. In those cases, surely the necessary training was very hard for pilots so, why not now for minor updates?
  • $\begingroup$ 1. you're comparing apples to oranges when comparing Airbus and Boeing approaches, they are two different companies and what one does does not mean the other thinks is the best - 2. "it should be because of more safety, readability, and situation awareness" [citation needed] $\endgroup$
    – Federico
    Mar 10, 2017 at 14:01
    $\begingroup$ 1) It's beacuse I don't understand different approach that maybe someone could explain something about this topic, like in other questions was explained different approach between joystick and yoke of different manufacturers. 2) I suppose that these could be reasonable "reasons" for update, if you have other indications, please provide them :-) $\endgroup$ Mar 10, 2017 at 14:06
    $\begingroup$ Because then you have to retrain and requalify all of the existing A320/A330 pilots, as well as getting rid of all your maintenance expertise and spare parts, becomes expensive. The 747 was a little different because they also got rid of the flight engineer. $\endgroup$
    – Ron Beyer
    Mar 10, 2017 at 14:09
  • $\begingroup$ (ma che t'hanno fatto di male gli articoli determinativi?) anyway 1) ok, fair point. be aware though that the answer is not necessarily "logical" (i.e., marketing might be involved) 2) my "citation needed" referred to the given reasons, i.e. I would like you to show that those benefits actually are there, before asking why they have been neglected. $\endgroup$
    – Federico
    Mar 10, 2017 at 14:13
  • $\begingroup$ @RonBeyer That looks like an answer. (I guess you didn't post it as one because you don't know that it's the reason; but you could always phrase it as "A significant disadvantage of doing it that way would be...") $\endgroup$ Mar 10, 2017 at 15:24
25
The short answer is that it's what the market wanted. There is always a lot of discussions between the airlines and manufacturer's before Airbus or Boeing commits to building a new aircraft. In this case both Boeing and Airbus came to the same decision -- the airlines were being driven by one single factor to replace their A320 or B737 fleets, they just wanted to reduce fuel expenses. That's why the Airbus is the 'neo' new engine option.
The airlines made it clear that any new aircraft purchases would be based on operational savings and that's primarily driven by fuel burn and the resulting costs. The solution to that is a new engine. Putting in a new flight deck is a huge expense for the manufacturers which would drive costs up and the airlines won't pay extra for something that doesn't save them money.
There's no cost benefit to a new flight deck, especially when (as others noted) you have a huge investment in an existing fleet. In fact, all it's likely to do is add costs. With a new flight deck you'll have a huge increase in maintenance and spares costs due to the need for stocking more parts with new part numbers (just adding a part number to a logistics system costs significant money.) You'll also need new crew training simulators due to the different displays and controls, whereas the neo option can be handled with software upgrades. And if it drives a need for new type ratings, that would mean more training costs and making sure you have the crews with the right rating at the right time.
In my experience in 20 years dealing with this market, airlines only spend money for two reasons:
  1. It will increase their profit margins
  2. The FAA (or other regulatory agency) mandates that they have it.
Aside from that, you should consider Airbus' side. They're trying to sell airplanes and they have to compete with Boeing. Since the avionics architecture is quite different between the A320/A330 and the A350, moving to it would add huge costs and a couple years delay in entry into service. They also have to deal with the fact that airlines don't want to see a big price increase. Prices for the A320neo and B737MAX are not significantly higher than the current/older versions. If the competition can offer a 7 to 9% reduction in fuel burn for approximately current prices, spending an extra 2 or 3 years to match that with a new flight deck means a lot of lost sales in the interim. And you probably won't make enough margin to recoup the new flight deck costs.
  • $\begingroup$ Great answer. You may want to put in something about the added costs of training pilots & maintenance on a new flight deck plus the cost of spares already in stock that are no longer usable, in addition to the manufacturer cost of refitting the A350 flight deck into the A320/330 cockpit. $\endgroup$
    – FreeMan
    Mar 10, 2017 at 15:35
  • $\begingroup$ @FreeMan Good point, but I have to deal with it in spare moments between real work. $\endgroup$
    – Gerry
    Mar 10, 2017 at 16:47
15
To add to Gerry's answer (and this will be slightly too long for a comment), there is a huge disadvantage to drastically changing the cockpit when going from an A320 to the A320 NEO or from a B737-300 to the B737-700, or 737 NG to 737 Max, and that has to do with the existing fleets.
If you keep the cockpit basically the same and just add what new switches are needed for the new engines, then most if not all operators can qualify their pilots in both models, and integrate the new arrivals into the fleet with minimal disruption. Need to substitute a NEO for a standard 320? No big deal, the same crew can fly either one. If the cockpits are wildly different, then the new jet is essentially a different type rating, and the pilots will have to be qualified (Edit: "qualified" in the airline sense -- current & qualified, not just type-rated) in one or the other, but not both at the same time. So when you substitute an aircraft, you have to change out the crew as well. That adds up to a lot of overhead, training costs, and scheduling inefficiencies.
In the case of the A-350, it IS a whole new aircraft, and nobody would be qualified in it at the same time as the A-330 or A-320, so there's no great need for backward compatibility. But in the case of the A-320 NEO, keeping commonality with the existing A-320 fleet so that pilots aren't restricted to one or the other is a big deal.
Now, I can just hear the objections... you said "B737-300 to B737-700 -- that's steam gauges to glass!" Yeah, sort of. BUT: Boeing "dumbed down" the 737 NG cockpit tremendously compared to what it could have been so that operators of the 737 classics could keep their pilots qualified on both the classic and the NG simultaneously. There was the "6-pack under glass" option for the NG displays, which made the NG display look like round dials, so that pilots used to the Classics had reasonably similar displays when they flew the NG. Less noticeable but still important, the overhead panel and the automation of the NG's was kept essentially the same as the classics, even though advances in automation would have enabled a FAR more modern approach to nearly every system in the aircraft and their management.
"6-pack under glass" depiction The option to digitally display round dials -- source page.
Another image -- showing how even the engine instruments were not much more than digital depictions of the round dials: Photo of old-style 737 NG instrument panel Original link.
Consider: the 737 NG is a more recent design than the 777, but the 777 aircraft in 1996 had automation light years beyond what even the 737 Max rolling out this year has. The overhead in the Max looks essentially identical to the overhead in the NG, very very close to the overhead in the Classic, and not dramatically different from the overhead panel of the 737-200 from the late 1960's! Why? So that airlines never had to segment their crews.
If the 737 Max were being rolled out "in a vacuum" today, its cockpit would look a lot more like the 787's -- which was mostly a "clean sheet" design (some commonality with the 777 flight deck). As was the A-350 -- clean sheet of paper. But the B-737 Max and the A-320 NEO aren't "clean sheet" designs and keep significant commonality with their predecessors, because that's what the airlines insist on.
For better or for worse.
  • $\begingroup$ I agree with the answer but you have an implication that an A320CE can't also be qualified on an A320NEO, which isn't true. Same for having a pilot qualified on the A350 that could not also be qualified on the A320/330, which also isn't accurate. Adding a new type rating doesn't remove the old one... $\endgroup$
    – Ron Beyer
    Mar 10, 2017 at 17:13
    $\begingroup$ Not trying to imply that the same pilot couldn't be qualified on all versions of the A320 at all -- quite the reverse! As to the 320/330/350, the type ratings would all still be there, but in practice airlines don't tend to keep pilots current on multiple types, so an individual would, at any one time, be either "an A320 pilot" or "an A350 pilot", but not both. Of course, having been thru the course in the past, training would be quicker to go back into it & there'd be no need for a type-rating checkride. But "current+qualified" on multiple types at once is rare-to-never for most airlines. $\endgroup$
    – Ralph J
    Mar 10, 2017 at 17:19
  • $\begingroup$ "...and the pilots will have to be qualified in one or the other, but not both at the same time" Maybe change the word "qualified" to "current"? Probably the same with "A-350, it IS a whole new aircraft, and nobody would be qualified in it at the same time as the A-330 or A-320,", it just sounds like you are saying that a pilot cannot be qualified in both, which is possible (and probable for an A320->A350 transition), but most likely wouldn't be current in both. $\endgroup$
    – Ron Beyer
    Mar 10, 2017 at 17:54
    $\begingroup$ Edited to incorporate that. For an airline, if you aren't current in whatever, then today you aren't qualified to fly it for them. A pilot who flew the 737 two years ago but is now flying the 777 may be "qualified" to fly the 737 in the FAA eyes for Part 91, but for his airline, no, he isn't, and they wouldn't put him in that airplane to fly it under any circumstances. As I mentioned, the requal training would be shorter than an initial course if he went back to the 737, but it would absolutely be re-QUALIFICATION in the aircraft as far as the airline was concerned. $\endgroup$
    – Ralph J
    Mar 10, 2017 at 18:32
  • $\begingroup$ @RalphJ Airbus has a scheme out that is EASA and FAA backed called Cross Crew Qualification, and applies to all Airbus FBW aircraft, allowing crews to be type rated on multiple Airbus types with highly reduced currency requirements. Many airlines take advantage of this. $\endgroup$
    – Moo
    Mar 11, 2017 at 10:50
The short answer is money. The B747-400 and B737-NG are indeed very different airplanes from their predecessors. So much so that they were deemed different type ratings. Getting a new type rating for pilots at an airline is a much more rigorous task, and expensive. Consider the administration overhead, to add the necessary Ops. SPECS, Aircraft Operations Manuals, etc. and have these all approved by the FAA or equivalent, and add in mechanic retraining and certification and you've got a huge investment.
The NEO engines and the planes themselves are a little different operationally. I fly them at work sometimes. But their not so different as to require a new type rating. The differences training we went through was a basic slide show, memorizing some new numbers, a handout of differences and a pretty basic test. All standard for differences training. No special or sim training was required. Even the mechanics just have written material to read through for the new engines. Huge cost difference. Bottom line, the airlines get the huge fuel savings and no required costs for retraining folks.
