During aircraft turns, will slip necessarily lead to altitude lost? During aircraft turns, will skid necessarily lead to altitude gain?
1$\begingroup$ Slips and skids just mean that the nose is not pointed in the direction of the turn. Unless you do something else wrong, the airplane should remain level. $\endgroup$– JScarryMar 4, 2017 at 19:57
3$\begingroup$ Why would skid ever lead to an altitude gain? $\endgroup$– David SchwartzMar 5, 2017 at 7:36
1 Answer
Think of a slip or skid that the aircraft is flying sideways (referred to as uncoordinated). This does increase drag, and therefore it requires either more power, or given sufficient speed, increased pitch to maintain altitude compared to flying straight through the air in coordinated flight.
A "skid" is when the aircraft nose is pointed inside a turn where the pilot feels centrifugal force outside the turn, like in a skidding car. In a slip, the nose is pointed outside the turn whereby the pilot feels a force of falling down into the turn. In straight flight, whether the nose is pointed left or right, uncoordinated flight is called a slip either way: a forward slip for losing altitude, and a side slip for landing.
