Knife-edge flight is an aerobatic maneuver where an airplane is flying on its side for an extended period of time without ascending or descending.
Notice it says aerobatic, i.e. for show. There is no point doing it on a mission (or otherwise) in an F-16.
Spoiler: it can't be flown in an F-16.
The flight control computer (FLCC) of the F-16 further incorporates limiters governing movement in the three main axes based on attitude, airspeed and angle of attack (AOA); these prevent control surfaces from inducing instability such as slips or skids, or a high AOA inducing a stall. The limiters also prevent maneuvers that would exert more than a 9 g load.
— Wikipedia
One source mentions 10° of beta (sideslip angle) as an extreme and unusual for an F-16.
Departure from controlled flight / Rudder input
The Aileron Rudder Interconnect (ARI) automatically provides rudder input according to pilot roll input
to reduce sideslip during turns. Pilot induced rudder does not improve turn performance but increases
departure possibility.
Yaw FLCS
Since the rudder is mostly controlled in flight by the FLCS through the ARI (Aileron Rudder
Interconnect) the pilot should in theory have no need to use the rudder in flight. To prevent pilot
induced rudder movement which can create adverse effects the FLCS automatically limits its use.
Rudder authority is reduced as a function of AOA, roll rate and CAT config to prevent departure from
controlled flight.
— BMS manual
Note: Crosswind crabbed flight is not a sideslip. The flight is coordinated (ball centered). Since the wind pushes the plane off track, the pilot corrects by pointing into the wind, that's all.
Just as tailwind or headwind has no effect on the flight dynamics, so is the crosswind. A plane flies inside a mass of air, if the mass of air happens to be moving, it only affects the navigation (where the plane is actually going, and how fast/slow).
for general aviation and civilian planes
. You may wish to limit your scope to, let say, civilian aerobatic aircrafts only. $\endgroup$ – kevin Mar 2 '17 at 13:44
