15
I see lots of great questions related to Victor Airways, but I haven't seen any which indicate why someone would want to fly one or what really makes them special or unique.
I get that they are radial of a VOR to another VOR and that certainly provides an indication in determining what that radial is if you wanted to fly from one VOR to another, but I do not understand the value of defining it as an airway beyond that.
What is the purpose of indicating things such as width of the Victor Airway, or altitude or any other attribute? Is the concept that it would be frequently travelled and thus these attributes make it a little more controlled and thus safe?
In short: Other than providing an easy way to determine a radial from one VOR to another, what is the purpose of a Victor Airway?
    $\begingroup$ When doing IFR or cross-country VFR, you can use Victor Airways as a "highway" system. It makes it easy to describe your path in a flight plan as well, especially if you need to avoid certain airspace. $\endgroup$
    – Ron Beyer
    Feb 21, 2017 at 18:12
    $\begingroup$ Related $\endgroup$
    – Pondlife
    Feb 21, 2017 at 19:54
  • $\begingroup$ Is it safe to say that these airways are meant for IFR traffic to fly? As a VFR pilot, I have never flown an airway. $\endgroup$ Oct 3, 2018 at 21:23
22
An airway (Victor or otherwise) is just a standard route for aircraft to fly on in the national airspace system - for all practical purposes they are literally highways in the sky (with the lanes being stacked vertically rather than horizontally).
This is part of the paradoxical logic of how ATC provides separation services for IFR aircraft: "You have to put them together to keep them apart." -- In an environment with no radar, or in crowded airspace, having everyone following a standard routing ensures that you know what each plane is going to do. If you have 10 aircraft all flying along an airway and each separated by altitude or time you know they won't hit each other
We define the attributes (width, minimum altitude, etc.) of a victor airway mainly for purposes of obstacle clearance:
A VOR has a specific degree of precision in its measurement, and if we assume the maximum distance from the VOR (the widest degree of arc) and the maximum allowable "slop" in the VOR receiver/indicator in the aircraft that means an aircraft that thinks it's "on the airway" will be somewhere within a given width around the defining radial: For Victor airways that width is 8 nautical miles - 4NM on either side of the centerline radial - or 4.5 degrees if the VORs are more than 102 nautical miles apart.
Those numbers may sound like they're arbitrary, but they aren't: If the VORs are exactly 102 nautical miles apart then the width of the airway at the 51 nautical mile midpoint between the two VORs is - you guessed it - 4 nautical miles. The further apart the VORs are the wider the center of the corridor becomes, accounting for the fact that a degree of arc gets wider as you get further from the VOR.
Airways are an IFR construct so if we continue on the assumption that the plane is in the clouds and the pilot can't see anything then within the airway corridor the aircraft needs to be clear of any obstacles (towers, trees, etc.), and of course it needs to be able to receive the VORs that define the airway. The combination of those factors and a few others will determine the minimum altitude at which a given airway can be used.
Note that much like ground highways airways are not always the most direct or convenient way to fly from one location to another. In particular the Victor airways are defined by VOR radials (or the intersections of such radials), but they're not always a straight line between two VORs.
As an example, take a look at this utterly contrived flight plan for the purposes of illustration: The airway I picked (V451) will take me from Groton VOR (GON) to La Guardia VOR (LGA), but it bends in three places on this route: CREAM, KEYED, and NESSI (not labeled on the sectional, but its the bend southeast of Bridgeport). A straight line between the two VORs would be the 265 radial from Groton direct to La Guardia: A much shorter distance, but not a "standard" airway routing.
  • $\begingroup$ Separating planes on the same airway is trivial. What is the main advantage is that you can have a prepared index of which airway intersects which others. That allows quickly and easily checking which flight-plan conflicts—and therefore can't use the same flight level—with which others even when they have completely different routing. $\endgroup$
    Feb 22, 2017 at 21:30
To add to @voretaq7's answer, there are a few more benefits of airways over direct VOR to VOR routing:
  1. Airways can bend a locations besides a VOR (e.g. V248 between SNS and PRB VORs bends about 10 miles from PRB).
  2. Airways can span across several VORs, much like the interstate system. For instance, V27 starts at Seattle, and follows the west coast all the way down to San Diego, passing through several VORs, and several turns along the way. If someone's flying IFR, the flight route could simply be "SEA V27 SAN" and everyone concerned knows exactly what it means.
  3. Airways also serve to provide obstacle clearance, and often it's quite a bit lower than the OROCA in the neighbouring (usually, mountainous) terrain. If you're flying off airway, you need to fly much higher, which may be outside your aircraft's capabilities
