Once when I was on a plane that was about to land, the cabin crew came around and they were spraying these small canisters. I've been on many flights but it was that particular flight where they did the spray. Can someone please tell me what those spray's are?
4$\begingroup$ Where were you flying from and to? $\endgroup$ – GdD Feb 13 '17 at 15:44
4$\begingroup$ It's bug spray. cntraveler.com/stories/2016-02-19/…. Also here: transportation.gov/office-policy/aviation-policy/… $\endgroup$ – PerlDuck Feb 13 '17 at 15:47
4$\begingroup$ Maybe the passengers just smelled bad... $\endgroup$ – reirab Feb 13 '17 at 20:50
22$\begingroup$ .....chemtrails (dun, dun, DUNNNN.......) $\endgroup$ – Carlo Felicione Feb 13 '17 at 21:12
3$\begingroup$ They normally announce over the PA systems before spraying them, you should listen to them more. $\endgroup$ – Notts90 supports Monica Feb 14 '17 at 13:03
The sprays are (usually) insecticides used to prevent the spread of invasive species and diseases.
The process of ‘disinsection’ is required under the International Health Regulations of the World Health Organization (WHO) on flights to and from certain destinations to prevent infectious and contagious diseases carried by insects and other volatile bodies. Rules established by the International Civil Aviation Organization (ICAO) require that disinsection does not injure or cause discomfort to passengers or crew. These rules permit the use of certain insecticides, which have the approval of and are recommended by the WHO based on their effectiveness and safety.
From the US dept. of Transportation
1$\begingroup$ +1. I've been on flights recently where insecticide was sprayed even though the countries involved were not on the US Department of Transportation list you linked, so either the list is incomplete or airlines are spraying even where it is not required. $\endgroup$ – Zach Lipton Feb 14 '17 at 11:40
1$\begingroup$ Why immediately before landing, rather than immediately after take-off? $\endgroup$ – Roger Lipscombe Feb 14 '17 at 13:04
$\begingroup$ @ZachLipton what country? If you read further down it says some countries require it on all flights from all countries that have zika. $\endgroup$ – Notts90 supports Monica Feb 14 '17 at 13:10
2$\begingroup$ @RogerLipscombe you could probably ask that as a separate se question but it would make sense to do it while on the ground in the unlikely event that someone had a bad reaction to the spray. $\endgroup$ – Notts90 supports Monica Feb 14 '17 at 13:11
1$\begingroup$ Air Namibia did that in the 90's on their flights between Frankfurt/Windhuk with a 747-200SP. I thought as child, or where told, that it was against air-sickness. Thinking about malaria and other possible diseases in northern Namibia this make now more sense :) $\endgroup$ – Peter Feb 14 '17 at 15:18
I was on an extremely long flight once, and the cabin crew walked up the aisles around the halfway point spraying canisters (about two in each hand) of what they said were disinfectants, required by the World Health Organization because we had so many people cooped up in a limited-air-exchange environment for so long. The idea as explained was to prevent passenger-to-passenger disease transmission.
However, on looking it up, I find the WHO's page refer to disinfection of aircraft as being primarily about killing insects, so there may have been an error in communication. See also this USA Today article for more information.
