The Space Shuttles glided to a landing in the atmosphere after reentry. They were not good gliders, aerodynamically speaking, so their glide slope angle was rather steep.
What was the glide ratio of the Space Shuttles in this phase of flight?
Sign up to join this communityThe Space Shuttles glided to a landing in the atmosphere after reentry. They were not good gliders, aerodynamically speaking, so their glide slope angle was rather steep.
The NASA website quotes an approximate ratio of 1
The shuttle was designed with a low L/D ratio (~ 1) because during the descent the spacecraft must be slowed from about 17,300 mph to about 250 mph at landing. (Source)
Note that glide ratio is normally equal to the lift to drag ratio - Wikipedia article - Aviation.SE Question
As far as I know the space shuttle is no longer in use. However, the glide ratios (more than one in different configurations) can be found on the Wikipedia page: Space Shuttle Wikipedia page. There it states that “The orbiter's maximum glide ratio/lift-to-drag ratio varies considerably with speed, ranging from 1:1 at hypersonic speeds, 2:1 at supersonic speeds and reaching 4.5:1 at subsonic speeds during approach and landing.”
