When representing a wing airfoil, often the low pressure is on the top side and the lift is positive:
In this case upper and lower sides are enough to understand the role of the surfaces, But this is meaningless for a rudder or for a compressor blade.
Are there names to identify the faces in relation with the direction of the lift. (In French specific names, extrados and intrados, are used in relation with camber.)
