I have heard that modern war planes utilize missiles which are directed to the heat of the enemy aircraft's engines.
Can a missile, shot by a fighter helicopter or jet, target the heat of the engines of the aircraft which fired it?
closed as off-topic by kevin, Sanchises, abelenky, mins, vasin1987 Feb 2 '17 at 22:15
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "This question does not appear to be about aviation, within the scope defined in the help center." – abelenky, mins, vasin1987
If this question can be reworded to fit the rules in the help center, please edit the question.
    $\begingroup$ Not really since you have a missile lock before firing. $\endgroup$ – Ron Beyer Feb 2 '17 at 14:18
    $\begingroup$ You mean, an accidental 'loop around', or something compared to radar targeting, where the reflection of the IR signature from the engines is reflected off the target? $\endgroup$ – Sanchises Feb 2 '17 at 14:18
  • $\begingroup$ Are you asking if a missle-launching aircraft can accidently shoot itself? $\endgroup$ – Dan Pichelman Feb 2 '17 at 15:16
    $\begingroup$ @RonBeyer But what happens if a friendly aircraft happens to cross the missile "lock-path" when it's already in the air and chasing a target? Infrared missiles IMHO don't have IFF. $\endgroup$ – jklingler Feb 2 '17 at 15:55
    $\begingroup$ @RonBeyer - Not really since you have a missile lock before firing - Not always. See: LOAL (lock-on after launch) $\endgroup$ – Hephaestus Aetnaean Feb 3 '17 at 6:54
