Why does the door slide mode need to be changed after the jetway or stairs are detached? Does the mode only need to be set when the door is closed?
    $\begingroup$ Don't know if it is a exact duplicate. I think the question is asking exactly when the door should be armed: when the outside stairs/jetbridge is removed, or if it can be done while they are still outside (which is bad, since the slide will impact the stair or jetbridge). $\endgroup$ – Thunderstrike Jan 28 '17 at 21:40
    $\begingroup$ Duplicates to SE are for duplicate questions, not two questions with duplicate answers. If the question is not a duplicate, it's not supposed to be marked as one. $\endgroup$ – CGCampbell Jan 28 '17 at 22:07
    $\begingroup$ @CGCampbell I happen to disagree, but that's what the voting system is for. Why don't you vote to re-open? If 5 other people agree with you, it will be so. $\endgroup$ – Simon Jan 29 '17 at 8:36
    $\begingroup$ @CGCampbell Note that the duplicate template says "This question already has an answer here". So, there is at least some ambiguity in when to VTC as duplicate. $\endgroup$ – Sanchises Jan 29 '17 at 9:08
