As a part of my ongoing research of a structural joint analysis of a Boeing 737, I have been looking for sources where I may be able to find the bending/deflection data during cruise conditions. I have found sources that may not be considered reliable, however; would anyone be able to assist me with the above data from source that would be considered valid for justification.
  • $\begingroup$ If you can share the sources you have found so far it could help to confirm with any new sources that are found. $\endgroup$
    – fooot
    Jan 24, 2017 at 19:15
  • $\begingroup$ I doubt you will find this information, it's probably considered proprietary of Boeing and not released to the public because the data is likely not required for certification. $\endgroup$ Jan 28, 2017 at 22:37
  • $\begingroup$ youtube.com/… $\endgroup$ Jul 12, 2017 at 10:19
