What is the maximum permissible slope for a table top Runway (elevation 1600 m) to be made on hill top ?
    $\begingroup$ Courchevel Airport I believe is the steepest public-use runway with an 18.6% grade. Operating in that airport requires a special endorsement and training. $\endgroup$
    – Ron Beyer
    Jan 16, 2017 at 17:29
    $\begingroup$ What country? What type of aircraft and operators? If there's no regulatory limit, there's probably a practical limit but it would depend on those details. $\endgroup$
    – fooot
    Jan 16, 2017 at 18:13
  • $\begingroup$ I think that's left up the pilot's discretion. $\endgroup$ Jan 17, 2017 at 4:41
  • $\begingroup$ I'm not completely sure what you're asking, but this question might be helpful $\endgroup$
    – Pondlife
    Sep 15, 2018 at 22:47
Most Part-25 certified aircraft have an operating limit of roughly +/-2% for runway slope, as most of the runways fall into this category.
It would be probably possible to certify aircraft for steeper slopes, however at a significant cost, as the flight test program would have to be extended to collect sufficient data.
It is also worth mentioning that anything over 1% upslope requires a bit of a different flare technique as opposed to a flat runway. Usually a bit earlier flare with a bit late thrust reduction does the trick. Extending the limit beyond 2% would probably require additional training, as the flare characteristics would be significantly different than that at a normal runway.
    $\begingroup$ Well, it is certainly possible to certify aircraft for steeper slopes, and some of them are, because there are places like VNLK (Hillary Tenzing Airport, Lukla, 12% slope) and LFLJ (Courchevel Altiport, over 18% slope). $\endgroup$
    Sep 16, 2018 at 20:56
