144
I have a picture of Air Force One I took fairly up close several years ago.
Air Force One at KBFI
Unfortunately, I don't remember if that was on arrival or departure.
Is there anything visible in the airplane's configuration (flaps, angle of gear?) that would indicate if this is arrival or departure?
  • 19
    $\begingroup$ What airport was this at, and do you know from what vantage point you took the picture? Looks like it may be fairly easy to determine what runway it was touching down or taking off from judging by the GA aircraft/hangers in the background. Should tell you what end of the runway you are looking at. $\endgroup$
    – Ron Beyer
    Commented Jan 11, 2017 at 18:14
  • 63
    $\begingroup$ Hey now, this isn't Puzzling.SE! $\endgroup$
    – fooot
    Commented Jan 11, 2017 at 19:42
  • 22
    $\begingroup$ The airport is KBFI, and I'm pretty sure I was standing on a ramp between A-9 and A-10 (south end of the airport). The hangers visible have green roofs visible here, which would indicate the plane is headed north, and is Landing. $\endgroup$
    – abelenky
    Commented Jan 11, 2017 at 21:03
  • 17
    $\begingroup$ Paging @Terry to the white phone. Resident 747 expert to the white courtesy phone, please. $\endgroup$
    – FreeMan
    Commented Jan 11, 2017 at 21:39
  • 38
    $\begingroup$ So, through the answers we have 100% ascertained that the plane is either taking off or landing. Great work! ;) $\endgroup$
    – Jamiec
    Commented Jan 13, 2017 at 14:34
9 Answers 9
110
The plane is probably taking off. The flaps are hard to see but they don't quite look to be extended enough for landing (Looks like flaps 20). On a 747 they extend to around 45 degrees (flaps 30, but they curve around more than that) for landing and have a huge, unmistakable profile. Further, we know it's KBFI and we know the plane is on 31L from the photo. Looking at the area we can deduce... (click for bigger)
...that the plane is about 3500ft into the runway proper, and 4500ft if we count the displaced threshold (and just off the ground) with the face of the southmost Jorgensen Forge building visible in the background (along with the green GA hangars).
At 3500-4000ft into the runway, hovering over the last markers in the TDZ, this seems quite late to be a landing. It might be a very deep float, but I would expect more precision from an Air Force pilot flying the CINC around. Air Force One is heavier empty, but probably overall lighter than a loaded 747-200 (and has powerful engines), so a 4000ft takeoff run for a light 747-200/VC-25 is sensible and probably more likely than an extremely late landing.
The flaps are more than minimum for takeoff, but seemingly less than normal for landing. Maybe 31L was running shortened that day? Entry at B10 onto the displaced threshold would also give them an extra 1000ft - V1 just past the aim point and rotate near the end of the TDZ markers seems sensible enough.
EDIT
After running a series of simulations, it seems difficult for the VC-25 to be able to takeoff from where we see it, even when starting from B10. The VC-25 is 525,000lbs empty. With only 100,000lbs load (fuel+people) it can takeoff by B5 at flaps 20, but only by lifting off below V2 (no wind). This has to be a landing (confirmed by the newly discovered set of photos), but it is a very late landing indeed.
It also seems that military aircraft of the United States are exempt from the requirement to execute a missed approach in the case that they can't make the landing within the TDZ by DA/DH (using "normal" maneuvers), so perhaps the pilot just didn't care and bobbled it in anyway. The plane did touch down in the TDZ, but just barely.
    $\begingroup$ The only real problem with this answer is that...it's kind of inconclusive. I mean, you've shown that it could be a takeoff (and I would agree, it's what I put in my answer too), but at the same time...what's to say the pilot didn't just have a bad approach and ended up floating the landing a bit? They would still have around 9,000ft to stop in, which should be more than enough... Establishing the location only makes it seem like it could still go either way. $\endgroup$
    – Jae Carr
    Commented Jan 12, 2017 at 5:43
  • 10
    $\begingroup$ The funny thing is, after we have figured out where the plane is, the community still has a dispute about whether it is takeoff or landing. $\endgroup$
    – kevin
    Commented Jan 12, 2017 at 9:34
  • 31
    $\begingroup$ @kevin This is slowly turning into the "blue dress" of Aviation.SE. Starting to wonder if it should be closed as "primarily opinion based".... But I'm having too much fun to do such a thing :D. $\endgroup$
    – Jae Carr
    Commented Jan 12, 2017 at 15:03
    $\begingroup$ @JayCarr I have seen a 747-200 take only 3300 ft to be airborne and 4000ft pulling up the landing gear. But also I have seen the same aircraft take further to touch its wheels on the ground when it has an unexpected tail wind. $\endgroup$
    – Bullfrog
    Commented Jan 13, 2017 at 11:09
  • 11
    $\begingroup$ So...abelensky found the series of photo this was taken from, see for yourself: drive.google.com/file/d/0BxQOwrukppp5WTlfaEFLTVNzTnc/view ...it's clearly landing. I guess the pilot did end up floating it pretty bad that day ;). $\endgroup$
    – Jae Carr
    Commented Jan 13, 2017 at 13:46
49
Please skip to the edit after the picture to see my actual answer. I'm leaving my original answer intact though, since other answers have referenced it.
I'm guessing that's it's taking off because:
  1. The wheels appear to be spinning (though the picture is kinda grainy so...)
  2. There isn't any smoke behind the tires, even though it would have just touched down.
  3. The nose angle looks a little high for a landing.
  4. The flaps look like they are set for take off.
For reference, here is a 747 landing. You'll note the flaps are extended much further:
enter image description here Image pulled from this youtube video, Copyright Robin Johansson
So, yeah... I'd say it was taking off.
EDIT-- I've had a long hard think about it and I've come to this conclusion: It can't be determined if the plane is taking off or landing from the picture.
Why? Well, let's examine the evidence...
Landing:
  • Tires -- Either they just made contact and haven't produced any smoke yet, or, they pilot managed to land it so gently that there's simply no smoke.
  • Flaps -- They don't look fully extended to me, but it's very hard to see the inboard flaps, and it's completely possible they are fully extended
  • Location -- Yes, as J... established, it's roughly 4000 ft down the runway. But perhaps the pilot was just having a bay day and floated it a bit. There's 6000 ft of runway left, they can still stop.
  • Nose Angle -- As fooot pointed out, it's entirely possible the nose is high because the plane is being flared.
Taking Off
  • Tires -- They wouldn't be smoking because they are being lifted off the ground.
  • Flaps -- They are definitely beyond Flaps 10 (normal configuration) but they may have them at Flaps 20 (which is an alternate procedure, from what I've read.) This actually reduces take off speed by 7 knots if, for some reason you want to get off the ground quickly. Which leads to:
  • Location -- If the plane is mostly empty (no press, just a couple people) and it's configured to Flaps 20, it's entirely possible to get off the ground in 4000', sometimes less. (I need a citation, I came across this doing a bunch of research last night, I swear!) If you combine that with J...'s idea that perhaps the plane entered at taxiway B10, then the plane could easily get off the ground by the time it reach that location if it is in the configuration I've described (Flaps 20, lightly loaded).
  • Nose Angle -- Well, it looks to me like it's angling up for lift. But again, this can go either way.
Conclusion: Seriously folks, this can go in either direction. This has basically become the "Blue Dress" of Aviation.SE. You can't easily tell if it's taking off or landing from the picture. Now, if someone else who was there that day could show up...maybe with weight and balance numbers...and some idea of how quickly Air Force One may have wanted to take off...maybe a grainy sound recording from the grassy knoll...and maybe a full video, verified by an independent panel of plane watches, the FAA, The Air Force, and the NTSB... Then we'd know ;).
But as it stands, it simply isn't possible to tell.
  • $\begingroup$ The picture appears to be well within the height when they would be expected to flare for a landing, which would bring the nose higher. $\endgroup$
    – fooot
    Commented Jan 12, 2017 at 0:32
  • 22
    $\begingroup$ "There isn't any smoke behind the tires, even though it would have just touched down." - No, it wouldn't. All wheels are still in the air. $\endgroup$ Commented Jan 12, 2017 at 9:51
    $\begingroup$ @AndréStannek I disagree, it appears to me that the center, rear trucks are touching the ground. But I'll also be the first to admit that it's hard to see. $\endgroup$
    – Jae Carr
    Commented Jan 12, 2017 at 14:53
    $\begingroup$ @AndréStannek Actually, I think if you look at J...'s (frankly excellent) answer, it does a great job of establishing where the plane is. The black pavement in the foreground is a taxiway, so I doubt it would be landing on that. The runway itself is beyond the grass :). $\endgroup$
    – Jae Carr
    Commented Jan 12, 2017 at 15:01
  • 8
    $\begingroup$ "This has basically become the "Blue Dress" of Aviation.SE". Strongly disagree!. This has basically become the "Gold and white Dress" of Aviation.SE $\endgroup$ Commented Apr 25, 2017 at 11:30
29
This picture is most likely taken during landing. The flaps configuration is the best clue. Flaps are extended more for landing than they are for takeoff. Compare with other pictures of Air Force One:
OP, brightness adjusted:
Air Force One detail from OP
Landing (original)
Air Force One Landing
Takeoff (source)
Air Force One Departing
The difference in flaps is a bit subtle but seems to match landing best.
Other good clues for cases like this, but that aren't of any help here:
Spoilers or reverse thrust deployed, which will indicate a landing. The angle of the photo is bad for seeing this, and it would be a little early for them anyway.
Smoke from the tires, indicating touchdown on landing. It could be off screen, but it's also hard to tell for sure if the tires are on the ground.
Clues from other scenery in the image that will help place the aircraft at a certain point on the runway. Landings should be near a threshold, takeoffs will be further down. There isn't much to go on in the OP but with a location it may offer clues.
Based on the lighting this picture was clearly taken around mid-day. We can look at the history of recent presidential visits to the Seattle area to see when Air Force One would have been on the runway around that time.
October 2015 - AF1 arrived during the day and left in the evening. If this photo is from 2015 it would have to be a landing. However, those photos show a more hazy/overcast sky while the OP photo looks more clear.
July 2014 - AF1 arrived just after 1500 local and left in the evening again. The shadows seem to suggest that the OP photo was earlier than 1500 local (hangars still in daylight, see 2010 photos) but it would still be more plausible than a departure.
April 2014 - AF1 flew to KPAE.
November 2013 - AF1 flew to KSEA.
February 2012 - AF1 flew to KPAE.
October 2010 - AF1 flew into KBFI, looking for a good reference.
August 2010 - AF1 arrived in the evening, and left during the afternoon. If the OP is from 2010 this would support a departure. But the photo of the departure has different lighting than the OP.
    $\begingroup$ Huh...see, I was thinking the exact opposite. To me the flaps don't look like they are nearly extended enough for landing. What makes you think they are fully extended? (And I say this having looked at a few images already...). Plus there's no tire smoke, even though the wheel would have just touched down... $\endgroup$
    – Jae Carr
    Commented Jan 11, 2017 at 17:16
    $\begingroup$ I think it's kind of hard to tell from the lighting in the OP but I'm comparing to other photos of the 747-200, and the inboard flaps will show the most difference. I'm working on reference pics. $\endgroup$
    – fooot
    Commented Jan 11, 2017 at 17:17
  • $\begingroup$ Does the enhanced photo not look closer to takeoff configuration than landing configuration to you? I admit, it's extended a little bit beyond your take off picture, but the VC-25 is kinda heavier than the normal 747 I thought...it just doesn't look nearly extended enough for takeoff. $\endgroup$
    – Jae Carr
    Commented Jan 11, 2017 at 17:24
  • $\begingroup$ The landing photo seems to match the OP best, but it's hard to tell without a comparable takeoff angle. The outboard flaps look close but the inboard ones are much further extended for landing, which seems to match OP. $\endgroup$
    – fooot
    Commented Jan 11, 2017 at 17:27
  • $\begingroup$ @JayCarr I don't think the VC-25 is heavier. They carry a lot less people, and the engines are very powerful for a 747 at its weight. $\endgroup$
    – kevin
    Commented Jan 11, 2017 at 21:16
21
Measured directly on the image, the angle between the cheatline and the runway is 5.5°; the true pitch angle of the plane will be slightly less than that, because of a little perspective foreshortening.
According to this document from Boeing, a typical liftoff attitude for a 747-400 is 10°. (The VC-25 in the picture is a modified 747-200, but none of the various aircraft in Boeing's diagram show a liftoff attitude of less than 7°).
Furthermore, the recommended rotation rate is 2 to 3 degrees per second, so if this image shows a departure, we must be looking at a moment only about two seconds after rotation was initiated.
Since the aircraft in the picture is definitely airborne (no matter which part of the picture is the runway, it is unmistakable that none of the main gear bogies have all four wheels on the ground), I conclude that it cannot be a takeoff – at least not an ordinary uneventful one.
    $\begingroup$ Did you take into account the fact that the photograph isn't level? And there's very little foreshortening, because the photograph is taken from close to side-on. $\endgroup$ Commented Jan 12, 2017 at 17:53
    $\begingroup$ @DavidRicherby: Yes, I measured the angle between the white cheatline and the runway, not between the cheatline and the edge of the photograph. The point I make about foreshortening is that 5.5° is an upper bound for the actual pitch. (Otherwise someone might complain that because of perspective we can't conclude anything from measuring on the photograph -- I'm merely pointing out that the direction in which perspective can change things is unambiguous). $\endgroup$ Commented Jan 12, 2017 at 17:55
  • $\begingroup$ Cool. I made an edit to clarify that but feel free to roll back if you think it's not useful. $\endgroup$ Commented Jan 12, 2017 at 18:04
  • $\begingroup$ very careful answer! that is a very good clue that it is landing indeed! $\endgroup$
    – dalearn
    Commented Jan 13, 2017 at 14:47
  • $\begingroup$ So you conclude it's a shallow landing? Why would they do this? For the comfort of the people on board as shallow landing means less vertical speed on touchdown? $\endgroup$
    – yo'
    Commented Jan 14, 2017 at 16:23
11
Why don't we actually analyze videos of Air Force One landing and taking off instead of just analyzing the pictures?
Here is a video of it taking of at Boeing Field on 13R (the same runway, but opposite direction).
Note that the B4 taxiway mark is clearly visible in the video. By counting the number of taxiway marks and comparing it to the airport chart:
  • Takeoff run began at the beginning of 13R
  • Rotation is initiated when the plane passes B5
  • Airborne is achieved around B7
So that makes up, well, ~75% of runway length.
Now,
  • Following J...'s answer, we can see the plane is somewhere between A10 and A9 when it touches down.
  • We also agree that the flaps setting is more than a conventional takeoff but less than a conventional landing.
  • Would Air Force One add more flaps for a short-field takeoff? Unlikely. They don't carry as much passengers and cargo, they have 4 engines, each engine is more powerful than a typical B747 engine, and they have a 10,000 feet runway.
  • The image is either taken moments after takeoff, or a split second before touchdown.
  • Note that the wheels are hanging, meaning they carry no weight of the aircraft at that point. If this was a takeoff, then rotation would have been initiated somewhere near the PAPI lights, between A10 and A11. How can it accelerate to Vr within such short distance?!
Therefore, I conclude: the plane is landing with a faster-than-average approach speed and a less-than-average flap setting.
  • $\begingroup$ That looks like a pretty lazy takeoff, to be honest. Same roll, but here rotation before B4 and airborne around AB youtube.com/watch?v=l4N10mXcHyI $\endgroup$
    – J...
    Commented Jan 12, 2017 at 10:49
  • $\begingroup$ Plus, the thing that's really making this debate kind of pointless in the end: we have no idea what the weight of the plane is in the picture, or in your video. Sometimes it's completely full of people and equipment, sometimes it's empty because it's just being ferried. A 747-200 can take off in 4000ft empty, but yes, it would take roughly 75% of the runway if full (and if you're being lazy, as @J... points out.) $\endgroup$
    – Jae Carr
    Commented Jan 12, 2017 at 15:12
  • $\begingroup$ @JayCarr I've heard Air Force One carries a lot of gear, so I doubt you can use the regular empty weight even if it's just the pilot. Anyway the plane was 2,920 ft from the end of the runway proper see my answer $\endgroup$
    – D_Bester
    Commented Mar 10, 2018 at 21:01
The plane is landing.
  • the engines are running on low power setting, otherwise there would be considerable blurring visible below the rear fuselage because of the hot exhaust plumes. In this picture the blur behind the main gear is similar to that in front of the main gear, consisting of bokeh and motion blur.
  • looking carefully you can actually see that the left main gear (inner or outer) has already touched the runway, and there is visible dark smoke from this obscuring the small plane on GA platform, the one (probably a Diamond or such) to the right of the Cessna with red tail. You might expect white smoke, but since it is in the shadow of the plane, it looks very dark.
  • The asphalt on the foreground is taxiway A. You can tell by the yellow dash line, the runway centerline is white, and the lines and gaps are considerably longer. This part of the runway 31L is about 4ft higher that twy A, so the perspective matches to this being a shot of the moment of touchdown (the location of the plane in the picture is already well established here, kudos for J... and D_Bester)
For reference, a crop of the original picture in question: enter image description here
The picture below shows the kind of blur that will be visible when engine is running at T/O thrust. The perspective is not exactly the same, but distances between photographer, the plane and the building in the background are a close enough match. Image source: pexels.com engine plume
(I will add more and better pictures when I get my hands on something not as mobile as the device I'm using now)
  • $\begingroup$ not sure that this answer adds anything not already available, given also that the sequence of images from which the original was part of, has been found years ago: aviation.stackexchange.com/questions/34586/… $\endgroup$
    – Federico
    Commented Feb 5, 2020 at 21:23
    $\begingroup$ @Federico this question does not have an accepted answer, and in addition to that mine gives new indisputable pieces evidence (this being the internet does not mean anyone has to accept them) that show the plane is landing. The pictures you are referring to are not available anymore, and hiding the answer into a comment does not seem to be fair anyway ;) $\endgroup$
    – Jpe61
    Commented Feb 5, 2020 at 21:37
    $\begingroup$ The task in this question is to analyze the photo, and conclude whether the plane is landing or taking off. Most of the aswers as they stand are not clearly stating either, as they lack definitive evidence on which to base the conclusion. $\endgroup$
    – Jpe61
    Commented Feb 5, 2020 at 21:40
  • $\begingroup$ I agree that the answer should be not hidden in a comment, but I do not agree with your statement that the photos are not available, I just downloaded them again. I agree that you add new points, sorry, I though that they got already discussed, since they did not sound new to me. $\endgroup$
    – Federico
    Commented Feb 6, 2020 at 6:34
    $\begingroup$ can't replicate. If I click on drive.google.com/file/d/0BxQOwrukppp5WTlfaEFLTVNzTnc/view I get to an image also in private mode with cache deleted. anyway, added a comment with a new link $\endgroup$
    – Federico
    Commented Feb 6, 2020 at 9:46
Don't be fooled by the black line which looks like that the plane is on the ground.
Enter image description here
The runway is marked with a white line, so the plane is still 3+ m in the air.
So I think it's landing.
    $\begingroup$ It really isn't. The wheels would not be level if it were in the air (the most reword trucks are level). You are looking at the taxiway, you can tell because there is an orange cone on it, and it's clearly nearer to the person taking the photo. $\endgroup$
    – Jae Carr
    Commented Jan 11, 2017 at 21:40
    $\begingroup$ Further, even if the plane were 3 meters in the air, it would have to be 3 m in the air on both takeoff and landing...so I don't follow your logic. $\endgroup$
    – Jae Carr
    Commented Jan 11, 2017 at 21:41
    $\begingroup$ but you have stated in your answer that "There isn't any smoke behind the tires, even though it would have just touched down." So i need to argue $\endgroup$
    – romanemul
    Commented Jan 11, 2017 at 21:46
    $\begingroup$ You can see the shadow on the ground underneath the plane, but nowhere in the foreground of the picture, so that suggests it is above the pavement directly under the plane, not the pavement in the foreground. Besides, the foreground looks a lot more like a taxiway with the yellow stripe. $\endgroup$
    – fooot
    Commented Jan 11, 2017 at 22:29
    $\begingroup$ @JayCarr The wheels aren't level. Look at this photo of a 747-200 that's definitely in the air. You see that the outboard bogies are at a very steep angle, and the inboards are at a much more gentle angle (almost parallel to the plane's long axis), just like the photo in the question. (In the question photo, the right outboard is clearly separated; the left outboard and the inboards are all on top of each other but you can figure out which is which.) $\endgroup$ Commented Jan 12, 2017 at 14:09
I can conclusively say the nose of the plane was about 2920 feet from the end of the runway proper (not including the extended area).
Notice the second door of the middle hangar lines up with the nose of the plane. To see where the next building starts just look at the roof line.
Here's my line of sight from the photographer lined up with the doors of the second hangar. enter image description here
Here's the measurement using google maps enter image description here
This agrees with the placement of the plane as described by J...
  • $\begingroup$ That is pretty impressive. I do know exactly where I was when I took the picture, and your red line, pointing to the hanger by Helicopters Northwest is extremely accurate! Congrats. :) $\endgroup$
    – abelenky
    Commented Mar 10, 2018 at 21:54
The absence of any smoke from the tires is reason #1 to suspect takeoff.
The flaps definitely aren't fully extended, but they're extended more than the minimum for takeoff. This means that more analysis has to happen before taking the position of the flaps as definitive:
If the runway is short, both takeoff and landing would have more flaps than if it were long, and the somewhat intermediate flap setting there would make sense for takeoff, not at all for landing. If the runway is long, you'd expect a lesser flap setting for takeoff, and the flaps shown might be reasonable for landing. Don't know what their practice is to always land full flaps or not.
Given the GA hangars in the background, I'll go out on a limb and guess that the runway isn't 10,000' long, and thus the flap setting is more appropriate for a short-field takeoff, rather than this being landing on a long runway.
Beyond that, the absence of spoilers isn't definitive, they take some amount of time to extend upon touchdown. Likewise, reverse thrust deployment wouldn't occur until the aircraft is definitely on the ground, so its absence in the photo doesn't drive any conclusion either way.
My best thought is, it's a takeoff.
  • $\begingroup$ The GA planes don't imply runway length, as there may be more than one runway on the airport. $\endgroup$
    – kevin
    Commented Jan 11, 2017 at 21:35
  • $\begingroup$ The OP stated he took the picture at KBFI, and so it must be 13R, which actually is 10,000 feet. The other runway is only usable by aircraft weighing 12,500 pounds or less, which excludes a 747... $\endgroup$ Commented Jan 12, 2017 at 2:43
  • $\begingroup$ Actually, I believe the runway is 31L (same runway, opposite direction) $\endgroup$
    – abelenky
    Commented Jan 12, 2017 at 14:20
