What is the temperature of the air leaving the combustion chamber of a CFM56-5C? I was wondering as I could only find out that the fuel burns at around 1500 Celsius but this can't be the same as the air temperature because the air/fuel ratio isn't 1:1.
    $\begingroup$ The air temperature will tend to reach the same temperature as the fire, and can easily be more than 1500 C. $\endgroup$
    – fooot
    Commented Jan 11, 2017 at 16:17
    $\begingroup$ What comes out of the combustor is a lot more than 'air', it consists of combustion products plus some unused oxygen and fuel, and nitrogen that didn't oxidize in the process. Its temperature should be mainly dependent on the flame temperature, minus whatever was lost on the (very short) way out. $\endgroup$ Commented Jan 11, 2017 at 18:25
10
Quick answer: At the design point considered, which is assumed to be takeoff conditions, a CFM56-5C combustor raises gas temperature to 1360°C (the share of the compressor in this raise is about 600 °C).
This is a common value found in modern turbine engines, a balance between fuel consumption reduction and turbine material capabilities (nickel super-alloy, more on that here and here).
Turbine entry temperature (TET) varies with thrust. Takeoff TET is maximal and top-of-climb TET is about 100°C less. Takeoff TET cannot be allowed for a long time, due to the damages which would be incurred by the high-pressure turbine guide vanes and blades.
Some details about turbine engine principles follow.
Station numbers
In turbine engineering, to facilitate description and comparison, steps in the Brayton cycle are identified by a station number.
(Source)
Additional stations are defined to reflect specific needs (e.g. for the cold flow of a turbofan). The full standard is known as ARP 755, see this old but free description.
The exit of the combustor (which is also the turbine nozzle guide vane leading edge) is station 4. In this nomenclature, Tn is the temperature at station n, Pn the pressure, etc. As an example, the sensor seen in the fan inlet of many turbofan engines is commonly referred as T12 or P12T12 sensor.
Gas temperature and entropy
Thrust which can be produced by the engine depends on the turbine inlet temperature (station 4), which is limited by materials.
There are two means of raising the temperature. The compressor raises the temperature by increasing air pressure, the combustor raises it by fuel combustion at (ideally) constant pressure. The later increases entropy due to the breaking of hydrocarbon chains.
This is visible on a so called temperature-entropy (T-s) diagram, e.g. this one for the CFM56-7B:
CFM56-7B T-s diagram. Source
We can see the compressor work between stations 0 and 3 (with no change in entropy in a perfect cycle) and the (ideally) isobaric raise in temperature and entropy between 3 and 4 as fuel chemical potential energy heats air.
The area under the curve is representative, along with the mass flow, of the net work of the engine (energy produced by the turbine minus energy consumed by the compressor), hence its efficiency. The area depends on two main factors:
  • How much pressure (and temperature) is raised by the compressor.
  • How much entropy (and temperature) is added by the combustor.
The goal is to achieve the desired turbine temperature with the highest efficiency. By increasing the pressure ratio of the compressor (the height of the left vertical segment) less entropy has to be added by the combustor (horizontal segment). This means less fuel.
There is a specific PR value, around 30-35, for which the area under the T-s curve is maximal. This value is indeed targeted by the engine designer. Looking at the previous diagram (oblique lines in kPa), we can see the PR used is around 30.
CFM56-5C
Four CFM56-5C were used to power the smallest A340. A340 manufacturing has been stopped, as 4 engines are no more a good option in the era of high fuel prices.
Your question indeed boils down to: What is T4 for the CFM56-5C?
From this document (in French):
which is a thesis by Elodie Roux, this table on page 198:
tells us the T4 temperature is 1633 K, that is 1360 °C.
    $\begingroup$ how did you find that, I also saw you found the plane with folding wings, how do you search these things so fast and accurately. I honestly think your advise could help the rest of my life! @mins $\endgroup$
    – SRawes
    Commented Jan 12, 2017 at 0:05
    $\begingroup$ @SRawes It takes many years and great dedication, grasshopper, to learn the ancient art of Google-fu. Few have the fortitude to attain the level of skill of Master mins. We are all... his humble disciples. [bows low, gong sounds] $\endgroup$
    – TomMcW
    Commented Jan 12, 2017 at 0:19
    $\begingroup$ I shall dedicate my life to the art of Google fu and train it to work for my whim! @TomMcW $\endgroup$
    – SRawes
    Commented Jan 12, 2017 at 1:04
  • $\begingroup$ I'm still in awe and seriously want to know how @mins $\endgroup$
    – SRawes
    Commented Jan 12, 2017 at 1:06
  • $\begingroup$ @SRawes: Try this query on Google. You're searching, in english, for CFM56-5C and T4, and do not want results for maintenance providers ("capabilities"). This answer is shown first, but quickly you'll see the relevant thesis from Elodie Roux. It depends on your search history as Google uses the history to customize results (if you searched recently for a chain saw, you may alas receive links for chain saw vendors during several months). $\endgroup$
    – mins
    Commented Jan 24, 2020 at 13:29
