In flight simulator, using the NAV setting directs the Autopilot to follow the FMS' pre-setup flight plan and will navigate the aircraft through each of the configured waypoints.
In real life, however, it seems almost a guarantee that ATC will provide some heading which is not necessarily the most direct route, ie. what your flight plan had configured. ATC will request you turn right or left somewhere around the waypoint you expected, but not where you or the NAV system would have turned.
Even in the simulator, if you use the built-in ATC, it will give headings that are not what the flight plan had expected... making the NAV button not very useful except when flying VFR without following.
It seems the autopilot HDG feature is used more often. Is this true in real life as well?
  • $\begingroup$ Why not just adjust the FMS to reflect what ATC provides for instructions? The FMS is easily reprogrammed in flight... $\endgroup$
    – Ron Beyer
    Jan 3, 2017 at 19:33
  • $\begingroup$ @RonBeyer My terminology is probably wrong, so please excuse me. When I fly in the simulator, I have my waypoints setup, but ATC navigates me usually miles away from the waypoint, or past the waypoint, before issuing the next heading. If you're suggesting to adjust each waypoint to a simple heading, I'm not sure how that would work? It usually tells you estimated time and miles left until the waypoint is reached, but you don't know what the waypoint is if it's just a heading... no? $\endgroup$
    – SnakeDoc
    Jan 3, 2017 at 19:36
  • $\begingroup$ I'm not sure your simulator is an accurate representation of the real-world. Usually IFR flight plans are "cleared direct" or "as filed", and are relatively rarely amended in flight. ATC shouldn't be calling your every turn, that is why you have flight plans. The only time you may get routed around is coming into a busy field for spacing, but even then if you are on an IFR flight plan you should be spaced in long before you get there. $\endgroup$
    – Ron Beyer
    Jan 3, 2017 at 19:41
  • $\begingroup$ @RonBeyer Perhaps I'm "doing it wrong" then. Typically I take off after getting clearance, and get transferred to Center. Then I fly whatever heading they told me at whatever altitude they want, until I get the next heading, etc. When I watch my map, I typically will be close to, but not on the purple line the FMS has setup between waypoints. I usually get my next heading somewhere around my expected waypoint, but not exactly on it. Sometimes I'm miles to the right, left, or beyond it before I get the next heading. I'm flying prepar3d btw, if it matters. $\endgroup$
    – SnakeDoc
    Jan 3, 2017 at 19:44
  • $\begingroup$ @mins I typically have it set to Clear Skies and Calm Weather. There is some wind, but not a lot. $\endgroup$
    – SnakeDoc
    Jan 3, 2017 at 19:46
No. The NAV mode follows VOR radial. The FMS might provide "virtual vor" and use NAV mode too, but usually there is a separate LNAV mode for FMS.
No.
  1. In real life, most of the time you follow the flight plan. And even if the ATC wants you to fly other route, they will tell you new set of routes or fixes to use and you punch them in the FMS, so you still fly LNAV.
  2. Exception is approach where it is common that ATC will have you fly downwind (opposite direction than the runway) and tell you to turn base and intercept the final approach, so there they will give you heading (and you use HDG mode on the A/P). But that is once during the flight. Sometimes also once on departure, but that's usually it.
  3. The ATC can also tell you to follow some radial of some VOR and that's where you use the NAV mode proper, not the LNAV mode used for following FMS.
  4. Your flight plan is usually not direct, but follows the defined airways.
I am not sure how realistic the simulator ATC is and would't expect much of it. You'd get a better result in something like IVAO where the controllers are played by real people.
The HDG feature is used when the ATC vectors you around. It usually happens on busy airports on approach and on really busy airports on departure, but enroute it is rare.
The LNAV feature is used most of the time. The NAV feature is indeed rare, because most of the time you use FMS, not a raw VOR.
There are essentially two scenarios on departure: an initial vector, or flying the departure procedure track immediately "off the ground."
In the former case, the instructions might be along the lines of, "fly heading 120, expect vectors to JEBBB" or "... to join the WHOZT5 departure." In that case, shortly after takeoff, the pilot would select Heading mode and fly the specified heading. At some point after that, ATC would issue a clearance to proceed direct to a fix, and then the filed route would be flown from that point on. So upon receiving this clearance, the pilot would proceed direct to the given waypoint by engaging NAV (or, given modern nomenclature, LNAV).
In the other case, the first leg of the departure corresponds to the "straight ahead" track of the departure runway, and LNAV is activated immediately after departure, and the aircraft will fly the magenta line as published. So in this case, Heading mode isn't used, unless ATC needs to vector the aircraft off of the published track. In that case, they can either issue a vector, or they can clear the aircraft to a later point in the procedure or along the route.
In modern ATC, it is very uncommon for an aircraft to be getting vectors enroute, simply because it is more workload for the controller with no benefit. Once you're away from the terminal area, they clear you on whatever route you've filed (or been assigned), and they don't have to do any more navigating for you. If they need to turn you off course for traffic, they will, but that's the exception, not the norm.
  • $\begingroup$ Additionally, more and more aircraft and ATC facilities support CPDLC (Controller - Pilot Data Link Communications). When enroute, ATC can data link an amended clearance. When the pilot accepts the clearance, the FMS updates the flight plan automatically. $\endgroup$
    – Gerry
    Jan 5, 2017 at 12:44
On FSX you have to change the NAV/GPS toggle switch to GPS to follow the preplanned route which is shown in the FMS display. Once you reach your designated airport the ATC will give you vectors to intercept the ILS. At this stage you need to enter the ILS frequency into the NAV1 and switch the toggle switch to NAV. The autopilot will then follow the ILS. Not sure how realistic this is with real life flying!
