Why are some LNAV/VNAV minimums lower than the LPV minimums for the same approach? See the RNAV (GPS) Rwy 5 approach at Scott Municipal (KSCX).
2$\begingroup$ Because TERPS criteria are weird and don't always seem to make much sense. $\endgroup$ – Ralph J Jan 2 '17 at 15:36
$\begingroup$ What's even more interesting is that the VGSI (PAPI) GP is below the RNAV GP... $\endgroup$ – UnrecognizedFallingObject Jan 3 '17 at 2:40
From what I could find out, it looks like they're unusual cases produced by the obstacle clearance calculations. There's a lengthy thread on PoA about it and the main points I saw are:
- LNAV/VNAV and LPV approaches are designed differently (the specifications are in FAA Order 8260.58)
- The Obstacle Clearance Surface (OCS; an imaginary zone that must be free of obstacles) is shaped differently for each approach type
- The OCS isn't at a fixed angle: it depends on the designer's choice of glideslope angle (e.g. for terrain clearance) and - in the case of LNAV/VNAV - on the prevailing temperatures at the airport
- The two approach types have decision points at different distances from the runway threshold, which also affects the glideslope requirements
- The resulting OCS may be at a higher angle for LNAV/VNAV than for LPV
The FAA Order has a lot of formulae to work it all out, but apparently the result is that if the calculations come out in a certain way and there's an obstacle close to the runway, it can penetrate the LPV OCS but not the LNAV/VNAV OCS. That means the LPV DA then has to be made higher.
In the PoA thread, every example of an approach with LPV minimums above LNAV/VNAV has an obstacle close to the runway. But the consensus was that the LPV minimums being higher than LNAV/VNAV is still very unusual overall.
Finally, although this isn't exactly the same scenario, an old FAA article on GPS approaches mentioned that the minimums aren't always what you would expect:
While [varying the obstacle clearance for an LNAV/VNAV approach] occasionally results in minima higher than the LNAV minima, the added safety benefit of a stabilized descent outweighs the difference in minimums
(That all refers to altitude, of course. The other part of the minimums is the visibility, but that should increase anyway as the DA and/or category increases. A high, fast aircraft needs to be able to see the runway from further away in order to descend safely.)
I saw an excellent answer here: http://www.askacfi.com/3854/lnav-lower-than-lnavvnav.htm (when you look at the page look for 'LPV') and as it looks to me it has to do with the width of the area evaluated for obstacles that is taken into consideration.
2$\begingroup$ We try to avoid link-only answers here in case the link breaks, and it's also easier to add comments and explanations. If you can expand a bit on the details of the obstacle considerations, it could be a good answer. $\endgroup$ – Pondlife Jan 2 '17 at 15:38
1$\begingroup$ That article addresses why the LPV is generally LOWER than LNAV/VNAV, without discussing a case as asked here where the reverse is true. That atricle is answering the question how an LNAV minimum can be lower than an LNAV/VNAV minimum to the same runway, which it does, although it also brings in LPV as being generally the best solution. Which it generally is, although this doesn't really address the question here. $\endgroup$ – Ralph J Jan 2 '17 at 19:22
$\begingroup$ Good point. So the question in itself should have been flagged for 'why is something true' when it is really false? So, if LPV is seen as the best approach method and yet other approaches have lower minimums I suppose I would edit the question to say something like 'do lower minimums imply a more dependable type of approach'.? $\endgroup$ – user6035379 Jan 3 '17 at 13:04
