I'm actually building a website where I want to display pictures of a specific aircraft. So I have the registration and I would like to show a picture next to each registration. For example I have the registration: A7-BCW
I want to get the picture in a way like this:
website.com/a7-bcw.jpg
Is there any site where I can do this and where I'm allowed to use the pictures for my site (watermarks are OK and I would also display the copyright information)? Of course there is no site where I can look up every aircraft around the world, I just need it for the common airlines like Qatar, Emirates, Singapore Airlines, Delta, United and so on.
    $\begingroup$ I suggest you send an email to the major aviation photo sites out there (airliners.net, jetphotos.net etc.). That will give you a much better answer then you will get here. $\endgroup$ – expeditedescent Dec 19 '16 at 11:37
Use flightaware.com.
They don't have every plane, but people can upload photos for a registration.
For example:
I search N6525W, and this page comes up. Then I can click the thumbnail picture of the plane in the top left section of the main body and I get this big picture.
Go there, and if you're lucky, the plane you're looking for happens to have a photo.
| improve this answer | |
  • $\begingroup$ I notice that you're needing this for web development in bulk. You need to make sure you're not stealing photos. Ask for permission first. $\endgroup$ – Ryan Mortensen Dec 19 '16 at 15:53
  • $\begingroup$ Pictures appear to be require self uploading. I have not uploaded any of my plane there, nor are there any Fixed Gear (FG) pictures of my airplane type loaded, only Retractable Gear (RG). flightaware.com is not very current for the flights it shows. I found a flight I did in February 2018 for a transponder checkout, where we did not talk to ATC. No subsequent flights, including several where we did talk to ATC, are shown. $\endgroup$ – CrossRoads May 10 '18 at 16:21
Have you checked what data is used at flightradar24.com (http://www.jetphotos.net)? Probably only commercial airliners, though.
