At maximum takeoff weight (listed on wikipedia as 10,494 lb (4,760 kg), 11,700 pounds (5,300 kg) with upgraded landing gear), what is the minimum runway distance required (not including safety margin) for an MQ-9 takeoff at sea level on a standard day?
It is also stated (same reference), that the improved landing gear provides a 30% improvement in landing max weight. What is the landing max weight and the corresponding minimum runway distance (again, without safety margin and on a sea level standard day)?
