In a gas turbine engine, what is the difference between Exhaust Gas Temperature (EGT) and Turbine Inlet Temperature (TIT)? I assume EGT is the temperature after the gas has transferred power to the turbine. Does that significantly change the temperature? Are they both proportional to engine power output?
$\begingroup$ Another measurement is the Inter-Turbine Temperature (ITT) $\endgroup$ – J Walters Dec 9 '16 at 22:36
EGT is just that - the temperature of the gas leaving the gas core at the jet pipe. TIT is the temperature of the gas in the gas generator as it exits the combustors and enters the first high pressure turbine stage. EGT will be significantly cooler - sometimes by as much as 1500°F! - than the TIT, as the enthalpy or internal and kinetic energy of the working gas is converted into mechanical work by the turbine, reducing the pressure and temperature of the gas flow as it exits each stage of the turbine. See the Brayton Cycle model for these kinds of heat engines.
Usually the power output for a turboprop or turboshaft is measured as the torque on the power shaft turning either the propeller or rotor transmission. Thrust on jet engines is usually gauged by the flight crew as N1, or the ratio of the current speed of the fan/LPC/LPT spool to its maximum speed. This is a bit misleading as the actual thrust the engine generates does not vary linearly with fan speed, but that is the benchmark.
EGT and TIT are not monitored for power output reasons so much as making sure the engine does not exceed its thermodynamic limits. Too hot a temperature in parts of the gas core will cause serious damage to the engine, requiring major overhaul and/or replacement of the entire engine or subsections. These temperature limits can exercise limitations on power or thrust settings for the gas turbine during operation to prevent overheating. On a free turbine turboprop, for instance, your power settings are bounded by both the torque limits of the propeller gearbox and another kind of hot section temperature called the Inter Turbine Temperature (ITT) which is the gas temperature between the high pressure gas generator turbine and the low pressure power turbine. These limitations cannot be exceeded in order to prevent engine damage and may restrict maximum power settings at both low and high altitudes.
$\begingroup$ Additionally, it is worth noting that on free-turbine turboprops, N1 (Ng) is also a limiting power setting parameter, and can be the limiting parameter when the compressor section is inefficient and nearing serviceable limits. $\endgroup$ – J Walters Dec 10 '16 at 5:10
(Source)
Yes, you're correct to assume the EGT will be cooler.
The hot accelerated gases will do work on the turbine, thus losing energy, both heat and kinetic.
EGT (or TIT) indicates whether the engine is running within parameters, but neither of them alone indicates how much thrust the jet engine is producing.
Only recently manufacturers introduced a thrust indicator.
The Airbus Cockpit Universal Thrust Emulator (ACUTE) converts the engine parameters into a single parameter that shows the thrust level as a percentage.
