28
Looking at this soviet aircraft:
Source: muzealnictwo.com
Engineers from two distinct eras have met and created this biplane with a turbine! It seems the two big pottery pieces are actually tanks. What is this aircraft and why such design?
  • 11
    $\begingroup$ Despite looking like toilets, I'm fairly certain the tanks are not pottery. :) $\endgroup$ – egid Dec 6 '16 at 1:28
    $\begingroup$ @egid, these were considered "bog standard" at the time. :) $\endgroup$ – Wossname Dec 6 '16 at 8:18
    $\begingroup$ From the source page the image caption is 'Samolot PZL M-15 Belphegor (fot. Autor)' - indicating it's a PZL M-15 Belphegor. (Yeah, I know there's already an accepted answer, but it was fairly simple... Didn't even need to be able to read Polish. :/ ) $\endgroup$ – FreeMan Dec 7 '16 at 15:25
    $\begingroup$ did you grab this from me off of Facebook? I posted it there yesterday. $\endgroup$ – rbp Dec 7 '16 at 17:36
    $\begingroup$ identical image facebook.com/groups/41407135412/permalink/10158045611150413/… $\endgroup$ – rbp Dec 7 '16 at 18:27
43
It is the Polish PZL M-15, as you can read in the image if you zoom in. From Wikipedia:
The aircraft was designed in Poland in response to a Soviet requirement for a new agricultural plane.
Agricultural airplanes fly slow and having a shorter span increases the number of (air)fields you can land on. That's probably why they decided using a biplane design.
The two tanks outside the fuselage could have several reasons:
  • Placing the chemicals further away from the turbine and pilot
  • Reduce the bending moment at the wing root
  • Shorter pipes between the tank and the spray nozzles
All this, of course, at the cost of a lot of drag. As explained in the image source page, fuel consumption was three times larger than other agricultural airplanes and it had a really bad maneuverability.
The jet engine was a requirement dictated by Aeroflot, who wanted to use the same type of fuel for their passenger and agricultural airplanes.
  • 14
    $\begingroup$ The silliest part is that they could have simply used a turboprop... $\endgroup$ – UnrecognizedFallingObject Dec 5 '16 at 23:42
  • 9
    $\begingroup$ another reason to put the tanks there is to make for shorter pipes between the tanks and the spray nozzles. This was a pretty large aircraft for a crop duster, meant for the very large fields at Soviet collective farms, so needed a high capacity or it'd have to reload too often. $\endgroup$ – jwenting Dec 6 '16 at 7:05
21
That's a Mielec M-15 Belphegor, the world's only jet powered biplane. A jet agricultural aircraft, manufactured by PZL Mielec in Poland for Soviet agricultural aviation. For its strange looks and noisy engine it was nicknamed Belphegor, after the noisy demon.
https://www.pinterest.com/pin/271764158735045150/
  • 16
    $\begingroup$ World's only production jet powered biplane. Others exist $\endgroup$ – Dan Pichelman Dec 5 '16 at 20:19
    $\begingroup$ Portions of this answer appear to be plagiarized from Wikipedia. $\endgroup$ – Columbia says Reinstate Monica Dec 6 '16 at 14:00
    $\begingroup$ Depending on the definition of "jet", Coandă-1910 can be counted as one. A biplane, naturally. $\endgroup$ – Agent_L Dec 6 '16 at 17:04
