Recently I found a paper about incorporating corrugated skins in aircraft called 'Corrugated composite structures for aircraft morphing skin applications' by C. Thill, J.A. Etches, I.P. Bond, K.D. Potter and P.M. Weaver
Source: Paper PDF
The paper talks about how the application of corrugated skins might provide benefits in morphing skins. The paper mostly talks about the structural benefits, as requiring less force to change the shape. Even if the structure might be covered with an aerodynamic surface, I'm still interested in the aerodynamic properties of a corrugated surface.
If there's a wing surface with a corrugating perpendicular to the flow, as shown below (flow coming from the left).
Image taken from Paper PDF
How will such a surface incluence the effectiveness of non-corrugated ailerons?
I image such a surface would lead to a much thicker boundary layer, thereby greatly reducing aileron effectiveness.
I'm mostly interested in large corrugations(~50mm) and low speeds(~80km/h). I'm not asking about the lift generation of the surface itself, only the effect on a non-corrugated aileron.
  • $\begingroup$ As I read the paper, the corrugated element is covered by an elastic membrane that serves as the actual surface skin. $\endgroup$
    – Wirewrap
    Nov 30, 2016 at 14:10
  • $\begingroup$ It mentions: "It is also planned to consider the aerodynamic consequences of having a corrugated wing profile at various Reynolds numbers." so it seems they are having some corrugated surface. $\endgroup$
    – ROIMaison
    Nov 30, 2016 at 14:23
    $\begingroup$ Sighardt Hörner to the rescue: Look here for data on the drag of grooves orthogonal to the flow direction. This is a non-starter with the dimensions and speeds you think about. Only covering this with a flexible skin will make this tolerable. $\endgroup$ Nov 30, 2016 at 16:59
  • $\begingroup$ @PeterKämpf Thanks for the pointer. However, Hoerner talks mostly about the drag development, whereas I'm more interested in the flow development. What kind of flow structures can I expect, and how will these influence anything that's behind the corrugated surface? $\endgroup$
    – ROIMaison
    Dec 1, 2016 at 13:25
  • $\begingroup$ @ROIMaison I'm speculating here, but expect oscillating separations (like von Karman streets) at the trailing edge. This will give you non-centering control surfaces with oscillating forces. No problem for hydraulic actuation, but not advisable for manual control. Still, flutter can be expected in either case. $\endgroup$ Dec 1, 2016 at 17:59
