18
From the little I know about vehicles in cities, nowadays concrete is preferred to asphalt for road construction as, while initially more expensive, concrete is supposed to be cheaper to maintain.
From a recent reading I understand India also uses asphalt in most places.
I have two questions:
  • Why haven't airports switched to concrete?
  • How can I check online the type of material used for passenger commercial airports around the world, especially transit hubs?
    $\begingroup$ Many runways are indeed made of concrete. Larger airports such as Charlotte, Louisville, Sea-Tac, etc., use concrete. Perhaps cost is controlling at the smaller fields that use asphalt. I don't know. $\endgroup$
    – user16289
    Nov 27, 2016 at 2:04
    $\begingroup$ I've never counted, but there are quite a few (at least in the western US) where the surface is dirt or grass. There are many others where the asphalt surface apparently was laid down decades ago, and not renewed since. For larger commercial airports (and many highways) an asphalt surface can be laid over a worn concrete base much more cheaply (and quickly) than redoing concrete from scratch. $\endgroup$
    – jamesqf
    Nov 27, 2016 at 5:42
    $\begingroup$ @casey It seems to depend where you are in the world. The major airports in the UK, for example, mostly have asphalt runways -- Manchester and Glasgow Prestwick were the only ones I could find with any concrete or partially concrete runways. Schiphol, CDG and Barcelona are also asphalt; Frankfurt has two asphalt and two concrete; Munich and Zuerich are concrete. This is going by Wikipedia; I sometimes wonder if editors there confuse asphalt (which is often given as the material but is never actually used), asphalt concrete (which most people call "asphalt") and concrete. $\endgroup$ Nov 27, 2016 at 10:56
    $\begingroup$ Concrete certainly isn't preferred for road construction in the UK -- we built some concrete highways in the 1970s and everybody hated them because of the road noise. There are still a few stretches left but, when they do need to be resurfaced, they're replaced with asphalt. Concrete is more useful in hotter climates. $\endgroup$ Nov 27, 2016 at 10:59
    $\begingroup$ I would say asphalt gives better friction. Is porous, so it can also drain when raining. $\endgroup$
    – Whacko
    Feb 21, 2017 at 10:06
5 Answers 5
37
Frankfurt Airport; a mosaic of concrete and asphalt
The runways at Frankfurt Airport are asphalt (old satellite imagery shows that they were concrete before), and the airport handles plenty of Superjumbos, the Airbus A380, so it's not a matter of handling heavy planes. All runways in big airports, even those covered in asphalt, have reinforced concrete foundations that vary in depth. They're deepest where the touchdown zones are located, shallower elsewhere. That's why runway extensions usually just add extra takeoff distance, but the landing zones remain the same, creating a displaced threshold.
Displaced threshold; can exist for other reasons
Zoom in
You'll see almost all the parking spots and holding areas for the runways are concrete, as well as the runway exits. This is where a plane is expected to be stationary. Concrete handles such stationary loads pretty well, while on a warm day the asphalt would deform.
Asphalt is called a flexible surface; concrete is called a rigid surface. Pavement classification number (PCN) is a standard used in combination with the aircraft classification number (ACN) to indicate the strength of a runway, taxiway, or apron (ramp).
Exposed concrete is notorious for cracking when exposed to extreme high and low temperatures. It's also more expensive to install and repair. But overall can be cheaper to install if you're already laying down concrete elsewhere, like most new airports, they just go for concrete everywhere, but it depends on where that new airport is located—
Hot Dubai; asphalt almost everywhere except parking areas and hold short areas
LAX; good climate and budget; concrete almost everywhere a plane touches
The variables come down to climate, use, load, budget, job creation, maintenance, etc.
A single runway (like at PBG) can also have both surfaces
Airport diagram showing the PCN for all runways; Flexible and Rigid
(NASA) Another point in favor of an asphalt runway, is that it's more gentle on the tires during touchdown (since it's flexible).
You can find runway data at airnav.com for US airports, elsewhere you'll need to check the airport's AIP, like this one for Amsterdam; check the section 2.12 RUNWAY PHYSICAL CHARACTERISTICS. Or try searching for a nonofficial runway data repository, there could be one.
    $\begingroup$ I was taught that asphalt was susceptible to fuel degradation, as it could infiltrate it and dissolve the actual asphalt holding together the aggregate, which was a reason to prefer concrete on hold points and runway extensions. $\endgroup$ Sep 11, 2017 at 13:00
    $\begingroup$ Furthermore, asphalt is faster to repair, which is another advantage to its use on runways, whereas a concrete runway may be out of order for a while if a slab cracks $\endgroup$ Sep 11, 2017 at 13:20
My first reaction to this question was that your assertion of "most" was untrue. Nearly all major airports (airline traffic) use concrete runways.
However, according to the Asphalt Pavement Alliance, some 85%+ of general aviation airports use asphalt, and they claim some majors as well. They claim that asphalt is more cost-effective and takes less time to lay down than concrete. So for those airports, where long-term budgets might not be guaranteed, it likely makes sense.
    $\begingroup$ "Nearly all major airports (airline traffic) use concrete runways." This is not the case. Heathrow, Gatwick, Schiphol, Charles de Gaulle, Dubai, Narita, Kansai, Bangkok Suvarnabhumi all have only asphalt runways, according to Wikipedia. And that wasn't me cherry-picking -- those were literally the first eight major non-US airports I thought of, except for the couple of European airports with concrete runways that I mentioned in my comment to the question $\endgroup$ Nov 27, 2016 at 12:49
You may find some disagreement from anyone who's actually driven on concrete roads...
Concrete as a surface is certainly more resilient to traffic in the short term. However the resulting road surface is significantly less smooth. This is very noticeable for European visitors to the US, where concrete is more widely used for road surfaces. In the UK, some sections of motorway were built in concrete in the 1960s, and these are universally unpopular with drivers. To my knowledge, roads in the UK at least are no longer built in concrete for this reason. It perhaps is less of an issue in the US due to the very soft suspension which is standard on US vehicles.
Concrete is also very much harder to repair when it develops holes, and those holes tend to be deeper and sharper-edged. Even after repairs, the resulting road surface will never be fully even. This makes concrete less suitable for roads which experience freeze-thaw conditions, namely most of Europe and the northern US. Concrete also has issues with thermal expansion, which makes it less suitable for places which experience high daytime temperatures (or at least this needs to be considered during construction).
As ymb1 says, you can put asphalt over concrete though, which gives you the best of both worlds.
  • $\begingroup$ Well, he did say for road construction without specifying who prefered it. The preferences of designers and construction crews don't implicitly match the preferences of motorists. :) $\endgroup$
    – T.J.L.
    Jan 15, 2019 at 15:23
In most cases, major aerodrome runway pavements are originally constructed using concrete (PCCP). Improvements (resurfacing,strengthening, etc.) on an operational runway are undertaken during off-peak hours (maybe nighttime) to avoid airport disruptions especially if an airport has a single runway configuration. But because of the necessity of runway improvement, asphalt concrete are utilized.
Newly laid asphalt may be used immediately after the asphalt curing time. Unlike concrete which cures in the first few days of paving, new asphalt may be allowed to aircraft operations as soon as it is compacted and cool.
The runways you have observed may be originally constructed using concrete but resurfaced using asphalt.
Asphalt or concrete decisions on FAA sponsored projects are made on life-cycle cost analysis. Sometimes one wins out over the other, but neither is inherently better.
