28
Could a new or a modified existing airliner, e.g., a Boeing 737, be fully powered by solar energy and make the normal length trips aviation-fuel powered aircraft make?
    $\begingroup$ The most likely way of achieving that would be a large ground-based solar-to-jetfuel plant, using one of several chemical processes. $\endgroup$
    – pjc50
    Nov 24, 2016 at 15:14
  • 11
    $\begingroup$ Define "solar powered"; oil comes from dinosaurs (et al.) who got so big and scary by eating other dinosaurs that ate plants that ate solar photons. $\endgroup$
    – Nick T
    Nov 24, 2016 at 16:06
  • 12
    $\begingroup$ Are blimps allowed? $\endgroup$
    – brian
    Nov 24, 2016 at 17:04
    $\begingroup$ To give you an idea of current solar technology: This is a 1 MW solar power plant. You need 90 MW to fly a B747-8, according to this answer. And you need to choose the departure time to fly only on daytime. If the cell efficiency was 100%, you would need only 1/5 of today's cell area. Still a big challenge (solar irradiance is about 1kW/m² in the visible spectrum, on Earth). $\endgroup$
    – mins
    Nov 24, 2016 at 20:26
    $\begingroup$ @brian Good luck getting a blimp up to Mach 0.75 or so. $\endgroup$
    – reirab
    Nov 24, 2016 at 22:27
8 Answers 8
46
Short answer: No
Long answer: No. Look at the solar impulse project, this is some of the best solar-electric technology that's out there, and it's barely able to carry one person, very very slowly. If you took an airliner, covered it in the best solar cells available and connected it to the best electric engines available it probably wouldn't even be able to taxi.
Some science here: The maximum energy density of the sun on the Earth is about 1300 watts/meters squared. About 30% is lost in the atmosphere so the best you'll get on the surface of the earth is about 900 W/m2. The 737, for example, has 102 square meters of wing area, that would equate to about 90000 watts (90KW) of sun energy hitting the wing. The best power conversion we have of solar to electricity we have is about 10%, so you would get at most 9KW of power from a 737 solar array. As we see from this answer it takes 90 MW (megawatts) of power to get a 747 into the air, assuming it takes about 1/3 or that (30MW or 30000KW) to get a 737 into the air, then that array will only generate 0.3% of the electricity needed, and that's the best possible case in the strongest sun. If it's cloudy or at night you are completely out of luck.
Any solution based on current battery technology is addressed here, and it's very much a no at this point.
Theoretically it is not possible that a solar powered passenger airplane could be as good as a jet-a1 powered passenger jet, this is because the energy from the sun is not sufficient even if you had 100% conversion to electricity. If battery technology were to become orders of magnitude better to the point its energy density compared to liquid fuels then it very well could, this is a long way off, the best batteries that are currently lab concepts are about 1/5 of the density of liquid fuel. Once batteries get there then solar power could charge them for the flight. It's actually just as possible that solar power could be used to make liquid fuel in a renewable way from CO2 and other elements in the environment. Bio-fuels are solar powered, but we can't make much of a dent in fuel use with them without taking food off of people's plates, and personally I'd rather eat!
  • 16
    $\begingroup$ I disagree with this answer purely because it discusses current technology and current power conversion "best case": when the question is asking for "Could there ever". The question therefore becomes a question of whether a more "best case" 80 kW (assuming a larger wing and 80% efficiency) is enough for an aircraft in cruise flight. Batteries (charged by land based solar panels) could supply the takeoff power, supplemented in the air by solar power for cruising. I suspect the answer is still no, but not quite for the reasons you give $\endgroup$
    – Jon Story
    Nov 24, 2016 at 15:34
    $\begingroup$ @JonStory even 100% efficient solars will only have about 3% of the power needed to get B737 up into the air. $\endgroup$ Nov 24, 2016 at 16:37
    $\begingroup$ @ratchetfreak if you read my comment again, I'm saying that "getting the 737 into the air" could be assisted by batteries, charged by solar power on the ground. Once at cruise altitude, an airliner uses significantly less power. And, of course, there's nothing to say that a larger wing is out of the question, nor solar panels on a flattened body design. I'm not saying those things would necessarily be enough, just that this answer only addresses the present $\endgroup$
    – Jon Story
    Nov 24, 2016 at 17:03
    $\begingroup$ you can use the body of the plane to put panels too, change the shape of the plane to get more lifting surface and more panel surface, slow down the plane a bit to get less drag, and use top of the line solar cell, with 44% efficiency instead of a mere 10% $\endgroup$
    – njzk2
    Nov 24, 2016 at 17:25
    $\begingroup$ would be interesting to see a calculation on how light the aircraft would have to be to enable a transatlantic flight with 100 people on board and with current solar panel and battery technology. If the weight would have to be negative, its safe to say it's impossible. However, if the weight would have to be only very low, it's merely improbable... $\endgroup$
    – mb21
    Nov 24, 2016 at 17:29
17
To cover a current-design airliner in solar cells and hook them up to electric engines spinning the fans will not work. Ever. Read @GdD's excellent answer for the reasons.
But today's car is also not a horse buggy with a gasoline engine. It has evolved and adapted to the possibilities. The same needs to happen to the airliner. Now let's look at what is possible. Looking back at the historic developments makes sense here, because the early pioneers also had very heavy and low-powered engines to work with, and still they could cross the Atlantic.
The first Atlantic crossing was planned by a Zeppelin crew in 1918, but the German government banned them from flying. So it fell to a British copy of a Zeppelin, the R-34, to cross the Atlantic in both directions in 1919. It had 5 engines of 270 hp each, which corresponds to 1006.7 kW. With a length of 196 m and a maximum diameter of 24 m the surface area available for solar cells would had been approximately 3000 m² which would provide just enough power if we assume solar cells with 40% efficiency and clear weather. Of course, cloud cover, lower solar altitude and especially nightfall would result in much lower power output from the cells. If we make the heroic assumption that the solar cells weigh as much as what can be saved in mass by modern construction techniques, a solar-powered, Atlantic-crossing airship is quite realistic. But it could not board many passengers and would be very slow.
Now to the heavier-than-air department. The Vickers Vimy which Alcock and Whitten-Brown flew across the Atlantic the same year had a wing loading of 40 kg/m². If we use a braced high-aspect ratio wing of the same wing loading, a very lightweight and efficient aircraft is possible. Covering the wing in highly efficient solar cells gives a power loading of 10 W/kg with 45% cell efficiency. How fast can we fly with that power? Let's assume an L/D of 30 and 90% propulsion efficiency, so we have 270 W of propulsive power per kg of aircraft. The minimum power required for flight is $$P_{min} = m\cdot g\cdot\frac{c_D}{c_L}\cdot\sqrt{\frac{2\cdot m\cdot g}{\rho\cdot S\cdot c_L}}$$ and expressing this in relative terms and concrete values at sea level: $$270 W/kg = 9.80665\cdot 30\cdot\sqrt{\frac{2\cdot 9.80665}{1.225\cdot 40\cdot c_L}}$$ yields a lift coefficient of $c_L$ = 0.475. This is actually quite low and corresponds to a flight speed of 28.73 m/s or 55.8 kts, something close to the maximum range speed of the Vimy. Covering the flight distance between La Guardia and Heathrow (2993 nm) would take 53.6 hours or two days and five½ hours.
If the sun would not set, a solar airliner would not be impossible - look at existing solar aircraft designs which have similar specs. The assumed high efficiency even allows to carry some payload, but that whole concept only works when the sun is shining brightly. To cover the dark hours, batteries must be taken along, and then the whole payload must be sacrificed to carry the batteries.
My answer is: If you cross the Atlantic in an airship, solar propulsion is possible in a not-so-distant future. Crossing it in a solar-powered airplane within reasonable time and in an aircraft sturdy enough to fly also in adverse weather will only become possible when super efficient batteries can be carried along to cover the power demands during nighttime. This is currently pure science fiction.
    $\begingroup$ Planes already have mo0re efficient energy storage than batteries: potential energy. Current sailplane endurance record stands at 56 hours which clearly includes nighttime when energy gathering is very limited. BTW, 2.5 days for crossing Atlantic still beats Queen Mary : ) $\endgroup$
    – Agent_L
    Nov 25, 2016 at 8:00
    $\begingroup$ @Agent_L: Do the numbers yourself. Even going up to record altitudes buys you a few hours, at most. The endurance records were flown in rising air before mountain ridges (or even sand dunes, in one case) $\endgroup$ Nov 25, 2016 at 8:06
  • $\begingroup$ Interestingly, the first cars where all electric - it has taken 100yrs to return to "old" proven technology. $\endgroup$
    – jwzumwalt
    Feb 27, 2019 at 7:31
Yes. Note that your question does not specify how frequently the trips are to be made.
Take your Boeing 737, put as many solar cells on it as you can, connect them to a plant that takes H2O and CO2 out of the atmosphere and turns them into something suitable as jet fuel. When the tanks fill up, fly somewhere.
From the numbers in GdD's answer the plane will have to sit for years between flights, though.
  • $\begingroup$ and worse, he doesn't take into consideration the considerable mass added to the aircraft by those solar panels, which would mean you need even more power... $\endgroup$
    – jwenting
    Nov 25, 2016 at 12:03
    $\begingroup$ Still you have a point here, Loren. Leave the solar cells on the ground, and synthesize fuel for jet engines. (see theconversation.com/… ) $\endgroup$
    – bogl
    Nov 25, 2016 at 12:34
    $\begingroup$ @JonStory which would be more than offset by the extra mass of the batteries as compared to tanks containing Jet-A $\endgroup$
    – jwenting
    Nov 25, 2016 at 12:41
    $\begingroup$ I took the OP's question as asking whether it was possible using solar power generation actually on-board the aircraft during flight, but, barring that assumption, yes, this is the correct answer. Technically speaking, we already use solar energy for flying airplanes. It's just that that solar energy was absorbed by some plants or other such lifeforms first, which later died and were converted into oil by lots of pressure over a long time, which was subsequently drilled out of the ground and refined into Jet-A. $\endgroup$
    – reirab
    Nov 25, 2016 at 23:21
    $\begingroup$ @jwenting Assume 100% efficiency, you still can't do it. An ordinary airplane uses more power than the sun shining on it. $\endgroup$ Nov 27, 2016 at 0:05
It is impossible with today's and tomorrow's technology.
Nevertheless, "ever" is a very, very long time. Nobody can answer 'no' to your question with certainty!
    $\begingroup$ While I think your conclusion is probably right, this answer as currently written is purely opinion with no supporting evidence or justification $\endgroup$
    – Jon Story
    Nov 24, 2016 at 15:35
    $\begingroup$ @JonStory Which parapgraph are you concerned about, first or second? $\endgroup$
    – bogl
    Nov 24, 2016 at 15:47
    $\begingroup$ When the sun becomes a red giant and the oceans boil, perhaps the intensity of flux will be more favorable to solar civil aviation. $\endgroup$ Nov 24, 2016 at 20:11
    $\begingroup$ @JonStory There is a misunderstanding. My point is that there is no such evidence. Nobody can exclude the possibility in the far future. $\endgroup$
    – bogl
    Nov 25, 2016 at 7:59
    $\begingroup$ @bogl unless you postulate that the laws of physics won't apply in the future, a lot of things can be excluded. You'd need a fundamental change in the theory and practice of quantum physics leading to a fundamentally new way of turning sunlight into electrical (or mechanical) energy in order to make the scenario of a solar powered aircraft happen, which seems highly unlikely as it would mean everything we know about matter and energy would have to be proven false, including everything we know works. $\endgroup$
    – jwenting
    Nov 25, 2016 at 12:02
This question doesn't specify whether the solar panels are attached to the plane or not. If the Boeing plane is restricted to it's own surface area, then the above answers are sufficient to explain NO>
Otherwise, if the solar panels are not attached to the plane, YES. With laser power. See here >
https://www.nasa.gov/centers/marshall/news/news/releases/2003/03-180.html
  • $\begingroup$ Are you sure? It is very difficult to get more than 5 times the solar irradiance to a plane from laser, because you need to cool the photovoltaic cells in the plane. See: rand.org/pubs/technical_reports/TR898.html . I was crunching some numbers, and for something equivalent to a current airliner, you want at least one order of magnitude more power density than that. Something like 100 times more than solar power. $\endgroup$
    – ReneSac
    Feb 5, 2017 at 20:26
Most of the answers assume the sollar energy must be haverested on the plane itself, but there is not enough area there. But why?
It is possible to use a huge ground-based solar battery to decompose water into oxygen and hydrogen. Or just use hydroelectricity - rivers are powered by the Sun. Hydrogen powered airplanes exist. A large commercial hydrogen aircraft could be built by 2020 or about.
  • $\begingroup$ Most answers assume solar energy must be harvested on the plane because that is the unique part of this question. Assuming the solar panels are not on the plane makes it a question of battery capacity, etc, which is addressed elsewhere in questions like aviation.stackexchange.com/questions/25281/… . You may also want to provide a link to this question about hydrogen powered aircraft: aviation.stackexchange.com/questions/18809/… $\endgroup$
    – Cody P
    Nov 29, 2016 at 17:20
  • $\begingroup$ Does not seen from the question. $\endgroup$
    – h22
    Nov 29, 2016 at 18:57
YES! it could be done.
I live 10mi from the first nuclear reactor in the world. It is a staggering thought to remember the United States went from the discovery of radioactivity to the nuclear bomb in just 40 years. What seems impossible today is less than $20 at Wall-Mart in 20 years.
I can see where a heavier than air hybrid blimp/flying wing like structure could satisfy all the requirements, A blended body would have a larger surface area than conventional airliner. I expect it to be done within the next 50 years - but will require thinking outside the present convention of what a passenger airplane should look like.
Competes with non-critical freight loads or short haul B737 market (primarily less than 500-600mi.
Gottingen high volume low airspeed airfoil
Boeing concept
I would say yes, but it wouldn't be the type where the solar panels are directly powering the fans. It would require a whole heap of the best and lightest rechargeable batteries and the whole airplane would have to be covered in stick on panels, at best it would decrease the rate of discharge of the batteries. The top speed might only be like 400 kph given you'd be simply using ducted fans rather than turbojet engines but that would still be cool. If it means a big decline in fossil fuel burning I'd personally be happy for flights to take twice as long.
