This is mostly with respect to large commercial airliners. I mean so many things can go wrong, then how have the engineers designed it to make it fail-safe? Or is it a very simple trick.
Also, are there any new developments in this area of landing gear, like lighter gear, or fixed gear etc.
closed as too broad by fooot, Federico, SMS von der Tann, aeroalias, J Walters Nov 15 '16 at 2:11
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    $\begingroup$ Given the amount of landing gear incidents that happen, I think there's a flaw in your premise that it can never go wrong. Landing gear failure can and do happen. $\endgroup$ – Dan Nov 14 '16 at 13:39
    $\begingroup$ FWIW, all (?) aircraft with retractable landing gear have emergency procedures to follow in case the gear doesn't extend. And pilots are regularly tested on how to follow them, at least in the case of those commercial pilots who have to do recurrent training. $\endgroup$ – Pondlife Nov 14 '16 at 13:44
  • $\begingroup$ @Pondlife That is at least true of all aircraft certificated under 14 CFR 23 and 25 (see §23.729 and §25.729) $\endgroup$ – J Walters Nov 14 '16 at 17:39
The short answer is extensive testing and backup/manual over ride systems. In reality there is not a whole lot that can go wrong, landing gear systems are fairly simple in design.
This varies a bit by airframe but most landing gear systems are pretty much the same. Basically every aircraft out there, from a single engine Piper Retract all the way up through a 747 has some form of manual gear over ride system. You can read about that in this answer here. So basically if the main system fails (and it happens) they have some kind of manual over ride to force the gear down. Granted there can be cases where the manual over ride also does not bring the gear down but you can only be so redundant. Some gear is also held in place positively, in other words there is pressure on the system holding it up so that should the hydrolics fail you dont need the pressure to get the gear down. Often the gear is oriented so that gravity and aerodynamics can deploy it.
Fixed gear is generally not a great idea on anything bigger than a small trainer. Fixed gear adds drag at the cost of a simpler airplane. You can read up on a similar question here.
I dont think lighter gear is something they are looking into to solve the gear deploy issue. Generally speaking you want the gear to fall down in the event of a failure so a little extra weight is not the end of the world.
