From this answer, "A tennis ball stuffed in between two cylinders - a common flight instructor trick to see if students are doing a thorough preflight".
A place between the two cylinders is not the expected place for the tennis ball to be, but how does in general this "trick" work? I tried to Google but only pull out the mentioned answer.
