-3
I recently saw a helicopter with the registration "N61NR" flying repetitive patterns back and forth over my house and from my observations, it appears that it was landing in a grass field near a school and that it proceeds to fly directly towards the nearest hospital with appropriate round trip times (I know this because I regularly see medical helicopters flying that way). Any ideas, flight maps, or general commentary about the helicopter itself? It has repeated this cycle 10+ times.
closed as too broad by Ralph J, fooot, Federico, Peter Kämpf, SMS von der Tann Nov 4 '16 at 21:53
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • $\begingroup$ Training for pilots/crews? Its difficult to say without knowing. Can you verify that N number? It says that it is an invalid number on the FAA site. N61NR is a Bell 206 registered to "SWOPE AVIATION LLC". $\endgroup$ – Ron Beyer Nov 4 '16 at 18:53
  • $\begingroup$ I'm pretty sure that was it but I will look more closely next time it comes by... $\endgroup$ – dalearn Nov 4 '16 at 18:54
  • $\begingroup$ ok, could be a 1 instead of an I, I suppose... any more about that helicopter? $\endgroup$ – dalearn Nov 4 '16 at 18:58
  • $\begingroup$ No, "Swope Aviation" doesn't seem to have a website or other online presence. The registered address seems to share a building (or very close address with) Swope Construction. $\endgroup$ – Ron Beyer Nov 4 '16 at 19:04
  • $\begingroup$ yes, it is a 1, not an "I" $\endgroup$ – dalearn Nov 4 '16 at 19:08
The aircraft N61NR is registered to "Swope Aviation LLC" as per the FAA N-Number Inquiry Site:
enter image description here (Source: FAA N-Number Inquiry)
Doing a little more research, the business located near the address in the helicopter registry is Swope Construction.
Without knowing more details it is difficult to say what this particular helicopter is doing. The flight is not being tracked on FlightAware as far as I can search. The helicopter's last recorded flight in FlightAware was over a year ago.
Anything I say is going to be pure guesswork, the helicopter could be leased to a crew for training, they could be checking routes, or doing some kind of survey work. Swope Aviation LLC does not have a dedicated website or online presence. If you are concerned about the operations that the flight is conducting regarding the safety to the aircraft or people on the ground, you can always contact the FAA to report the activity and they will investigate.
  • $\begingroup$ Since it is landing so close to one of Swope Construction's sites, I would assume that it is doing something related to that. Thanks for the great work! $\endgroup$ – dalearn Nov 4 '16 at 19:33
    $\begingroup$ Swope Construction, same address. Current and past projects. True aviation lover: "Chandler Swope founded Swope Construction and is also a helicopter pilot. He has piloted WVVA photographers shooting aerial video for the past 25 years.". Good story about WV11, at Swope farm. $\endgroup$ – mins Nov 4 '16 at 21:05
  • $\begingroup$ Nice find @mins $\endgroup$ – Ron Beyer Nov 4 '16 at 21:11
    $\begingroup$ @mins And the Google Fu master demonstrates his prowess yet again. Teach us sensei. [bows] $\endgroup$ – TomMcW Nov 4 '16 at 21:37
    $\begingroup$ It's interesting that a question closed as "too broad" comes up with detailed information mostly based off the tail number and some dudes on the internet. :) Good job. $\endgroup$ – Steve Nov 4 '16 at 23:41
